Author Topic: Light feel from front brake. Normal?  (Read 2184 times)
Offline Yoshimitsuu
Re: Light feel from front brake. Normal?
« Reply #25 on: September 18, 2018, 07:36:55 AM »
I tapped on the line and zip tied it overnight. Once I’m done, I just pump the lever? I did that and it felt relatively the same. Should I bleed after having tied the lever?
Offline Bankerdanny
  • Endeavor to persevere
« Reply #26 on: September 18, 2018, 08:36:01 AM »
No, you should not need to bleed again. The point of the lever trick is that air will naturally rise up through the line and exit into the reservoir.
« Reply #27 on: September 18, 2018, 08:55:05 AM »
Is your lind near the mc m higher than MC  entry point, ... that would definitely hold air.
Offline robvangulik
  • Honda Fourever
« Reply #28 on: September 18, 2018, 09:50:34 AM »
Be careful, you maybe can squeeze the lever to the bars, but while riding the salto mortale could be only a half squeeze away, and i think that was what Frank meant too....
Offline Yoshimitsuu
« Reply #29 on: September 18, 2018, 10:41:55 AM »
The line near the MC entry hole is not above it, but on the radial MC there is a line from the reservoir to the lever/piston area and I believe that line does go above the MC entry point. I’ll attach a picture.
