Along with my CB750s, I have other bikes, which most have hydraulic clutches to go along with hydraulic brakes, so I've bled a lot of lines. It's easy, if you are a little patient.
First, double check all connections for leaks. A tiny fluid seep is a massive air leak. Then, open up your master cylinder. Pull in the lever and release it slowly. If you are getting a poor fluid return, you should see tiny bubbles. If you do, leave the bleeder closed and just work the lever and look for bubbles. As the bubbles disappear the lever pressure will grow. If you are not getting tiny bubbles on the return, you may not be getting correct pressure from your master.
Don't worry about working the bleeder until you start feeling pressure on the lever. It will be obvious. Might have to pump it 70 times, but slowly.
Patrick
