Author Topic: What dissolves white powder in carbs ?  (Read 900 times)
« on: September 12, 2018, 06:30:54 PM »
 I dont wantvto derack this set of PD,s for 750 right now........just clean them up and see if it runs ok and engine sounds tight. .
« Last Edit: September 12, 2018, 10:02:00 PM by 754 »
Re: What dissolves white powder in carbs ?
« Reply #1 on: September 12, 2018, 09:25:05 PM »
 Well it was probably caused by water and is a type of corrosion. Even though the product CLR will attack that kind of metal for a short duration you may find that it will help remove it when applied with a small paint brush. I played around with a corroded set trying different things for fun before.
« Last Edit: September 13, 2018, 04:12:43 PM by ekpent »
« Reply #2 on: September 12, 2018, 09:33:51 PM »
Vinegar can be used.
I soaked my k6 carbs one by one in a pot with vinegar 12.5% model for 1 hour. Another pot with water and blew it dry with comprsesed air.
Offline smacd11
« Reply #3 on: September 12, 2018, 11:00:49 PM »
I'm using Power Kleen from Permatex (same company that makes Spray Nine) in my ultrasonic cleaner - it was recommended by them since it's non-flammable and will not attack aluminum.  So far I am very impressed by it.  It's available at Princess Auto.  Not sure how well it would work just as a soak without ultrasonic.  I bought a 22L ultrasonic so I don't have to split a set of 4 :D
Offline BRG-BIRD
« Reply #4 on: September 13, 2018, 06:25:58 AM »
Evinrude Top Engine Clean or Sierra Carbon Free, both are exceptional at cleaning carburetors and carb parts without damaging o-rings.
“You are either on something or onto something.” The Comman Man
Offline Deltarider
« Reply #5 on: September 13, 2018, 06:58:11 AM »
Yamaha Carb Cleaner, if you can still find it. Usually not sold but to professionals (toxic!)
CB500K2-ED Excel black
