Author Topic: The South Side Dive Bar  (Read 3338810 times)
Offline coldright
  • That's Ms.
  • to you
Re: The South Side Dive Bar
« Reply #23900 on: February 08, 2010, 08:54:00 AM »
I have to wear ear plugs.  Which year are you looking at?  Oh! And where are the pics you promised of the latest project????
Offline HavocTurbo
  • Angry little bastard of an
  • Can you tell?
« Reply #23901 on: February 08, 2010, 10:51:24 AM »
The 08 zx14.
Pics are coming. In the middle of moving a shop due to the landlord having the building foreclosed. Pfft.... #$%*. >:(
What's your email? PM it to me. I'll email you what I have. I'll have a full update sometime soon. ;D
'48 HD Panhead - Exxon Valdez
'78 CB550K - Fokker CB.3
'78 Honda CB750K - Mavrik
09 XL883L - No Name
Offline coldright
  • That's Ms.
  • to you
« Reply #23902 on: February 08, 2010, 10:55:20 AM »
Careful, you know I have a huge crush on you and your panda.  PM sent.
Offline my78k
« Reply #23903 on: February 08, 2010, 10:58:41 AM »
"Panda"?!?!? Is that what you kids are calling it these days??
Offline HavocTurbo
  • Can you tell?
« Reply #23904 on: February 08, 2010, 11:00:01 AM »
Can you think of a cuter more cuddly name for it?  ;D
09 XL883L - No Name
Offline my78k
« Reply #23905 on: February 08, 2010, 11:02:54 AM »
I know I am going to regret typing this but your Panda doesn't look all that cute and cuddly!!
Offline coldright
  • That's Ms.
  • to you
« Reply #23906 on: February 08, 2010, 11:05:20 AM »
IT SMASHES!
Offline HavocTurbo
  • Can you tell?
« Reply #23907 on: February 08, 2010, 11:45:20 AM »
Hows that for cute and cuddly?
09 XL883L - No Name
« Reply #23908 on: February 08, 2010, 12:10:47 PM »
i'd cuddle with the last one  ;)
Offline mkramer1121
« Reply #23909 on: February 08, 2010, 12:53:55 PM »
anyone local ever swapped an auto trans on a newer car?  bought a 2000 alero w/ trans issues for cheap and i'm tryin' to see if its worth swapping in a used one myself for cheap or have someone else do it right...
Offline mark
« Reply #23910 on: February 08, 2010, 01:19:32 PM »
not fun on the ground but do-able.
F you mark...... F you.
Offline mkramer1121
« Reply #23911 on: February 08, 2010, 01:43:37 PM »
doable as in a weekend or a week?
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
« Reply #23912 on: February 08, 2010, 03:31:55 PM »
this is how us shade tree mechanics do it:
you'll have to drop the sub-frame on some 8x8x8 blocks of wood and jack up the car body real high with a cherry picker or a block and tackle hanging from a tree branch.
     makes life a whole lot easier.
weekend job if you're dedicated.  week if you are distracted easily like me.
Offline Grnrngr
« Reply #23913 on: February 08, 2010, 04:00:38 PM »
 Doesn't matter much if it's automatic or standard, did my 94 Spirit in a day (autoFWD)  , put a clutch in my daughters 01 Civic (stdFWD) in a slow weekend (work,play,work,play), pulled the transfer case and trans out of my Bronco2, found out the new tranny wouldn't fit, had it all back together and running the same day....it's easy once you've done it a few times. probably just my imagination, but I think rear wheel drives are easier, just be ready for the oil coming out the tailshaft when you pull the driveline. Only trouble spot I can think of would be if it's necessary to remove/loosen the exhaust on yours...exhaust bolts can be nasty on any motor, the older the car, the worse they are
'72 CB750-K2 "PopCycle"
'73 CB750-K2 "Barney"
'77 CB750A
'83 Virago 500 (red)
'83 Virago 500 (black)
  • Like a well oiled
    • Undead Asphalt
« Reply #23914 on: February 08, 2010, 05:13:00 PM »
I did my civic plenty of times without dropping the sub frame.  and it only took a couple hours.
But I did that #$%* for a living for years, so...
Offline mark
« Reply #23915 on: February 08, 2010, 05:22:58 PM »
think it would go kinda like - jack car up real high. use handy engine hanger loop to hang engine. remove subframe. swap trans and reassemble.
still a pita without a lift.
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #23916 on: February 08, 2010, 06:00:11 PM »
Front wheel drive and me and my pop didn't care to touch it.
Not even clutches.
Kind of stuff I like to pay other people to sweat and toil over.
Offline HavocTurbo
  • Can you tell?
« Reply #23917 on: February 08, 2010, 07:30:08 PM »
X2 - Better buy some beer and lots of friends. You are going to need distractions for your frustration.
09 XL883L - No Name
Offline Frankenkit
  • Industrial Strength
« Reply #23918 on: February 08, 2010, 09:04:38 PM »
Not even clutches.
+1.  Your time is better spent on a motorcycle.  Car = Necessary Evil = let someone else struggle with it.  Unless you're highly skilled in these matters, let someone with the skill and equipment to do it, imo.
2012 CBR250R "Black Betty"
1980 CB650c- (sold) Delilah
1973 CL350- Lola?
Stuff for sale
Offline mkramer1121
« Reply #23919 on: February 09, 2010, 05:15:45 AM »
i'm not gonna do a rebuild, just swap in a used low mileage one...i know a rebuild is over my head...still troubleshooting it, could still possibly be any of the following that are causing the hesitation and hard shifting:
- Bad MAF Sensor
- Bad MAP Sensor
- Bad IAT Sensor
- Vacuum leak
- Bad IAT Sensor Harness
- Bad Fuel Pump
This is fun...yeah, not really
Offline 333
  • Time for change
« Reply #23920 on: February 09, 2010, 07:01:34 AM »
I stopped workin' on 'em when they got all them EE-lectronics and got smarter than me.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline ColinMc
  • There aint no pickle like a super pickle...
« Reply #23921 on: February 09, 2010, 07:54:16 AM »
- Bad MAF Sensor
- Bad MAP Sensor
- Bad IAT Sensor
- Vacuum leak
- Bad Fuel Pump
It would be a lot easier to test/fix those things instead of swapping a tranny first...
1976 CB750K - Cafe Project...taking forever
1984 Honda MB-5 - MB-8 conversion in process
2001 Ducati 748 - Built 996 motor sleeper
Offline Inkscars
  • grumpiness comparable to an
« Reply #23922 on: February 09, 2010, 08:09:10 AM »
Just rent a transverse engine hoist. You crawl under it and unbolt motormounts, then go up top and pull it up. then you can unbolt it from the engine, do the swap and lower it back down as quickly as your skill allows. I've seen it done in 20 minutes.
Oh, And HI, I'm going to get my leg finished on friday and then I'm going to get a gun.
Why? Cause I want one.
81 Hardly Davisson
Offline mkramer1121
« Reply #23923 on: February 09, 2010, 08:18:36 AM »
- Bad MAF Sensor
- Bad MAP Sensor
- Bad IAT Sensor
- Vacuum leak
- Bad Fuel Pump
The trans guy said it was the trans, I'm the one troubleshooting everything else, praying its one of the cheaper fixes.  There's tons of threads on the web about people w/ similar issues and it being fuel/vacuum related.
Offline CaféElite
  • 1975 CB550
« Reply #23924 on: February 09, 2010, 09:05:10 AM »
OHH really? I stopped at the olathe gun store yesterday looking for used taurus judge.
CB550's
