Author Topic: The South Side Dive Bar  (Read 3059282 times)
cb750dude
Re: The South Side Dive Bar
« Reply #34900 on: January 04, 2011, 01:56:00 PM »
anyone have experience replacing an AC compressor clutch?
Take the old one off, put new one on. done ;D
« Last Edit: January 04, 2011, 07:38:49 PM by CB750dude »
« Reply #34901 on: January 04, 2011, 02:23:53 PM »
Offline SOHC Digger
  • I'm not an
« Reply #34902 on: January 04, 2011, 03:42:24 PM »
Yes, on a Chevy S-10 4.3 V-6.  Get the rent-a-junk tool from Autozone and go to town.
« Reply #34903 on: January 04, 2011, 03:53:34 PM »
Just buy a Tsubaki heavy duty primary chain, yes they probably are a hundred smackers or so  but you can pretty much install and forget about that sucker once put in.
from where ... you gotta link?
« Reply #34904 on: January 04, 2011, 04:01:59 PM »
I bought a heavy duty primary chain from forum member Nippon, Ricky Racer should have them as well, not too sure if they make them for the 500 but if they do they are better than anything else on the market including the TSUBAKI....Send them a pm.... ;)
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #34905 on: January 04, 2011, 04:16:29 PM »
If Mick says those guys have better chains I would buy from them.
I think Spikey has a 550.
« Reply #34906 on: January 04, 2011, 04:28:26 PM »
I have a spec sheet somewhere on the chains those guys have and they are way better than any other chain on the market, PM Nippon and ask for the specs, thats if he can make them for the 550. I have the "Nippon" chain and they are visible stronger and wear rate is incredible....
  some info...
Reinforced Primary Chains for Honda CB 750 K0-K8, F1-F3
Technical background
These chains are newly developed using state of the art technology. The two important benefits of our new chains are:
-    Improved max. fluctuating tension: Sand blasted inner plates and improved surface finish (embossed), precisely manufactured seamless bushes and stronger bolts.
These chains have a higher load capacity and offer more reliability against chain breakage in high performance engines.
-    Better wear behavior due to larger joint surface and extremely wear-resistant surfaces of bushes and bolts (Bolts with chromium carbide deposition, bushes nitrated)
Chain stretch is minimized over the whole engine life, 0.2% after 60.000 miles.
These high performance chains are used in highly stressed chain drives of diesel engines. Besides high forces, the chains are also abrasive stressed by diesel particles. These chains are designed for lifetime durability (no exchange).
The stock chains (by RK) are the state of 1968, designed for use in gasoline engines.
Fluctuating tension
The important factor in chain breakage in engines is the maximum fluctuating tension, not the maximum tensile strength. The tensile strength in general is a multiple over the maximum occurring forces in an engine. Chains do not break because the tensile strength is exceeded, but because of material fatigue due to excess fluctuating tension.
Reinforced primary chain:
Max. tensile strength: 15.5 kN per chain
Max. fluctuating tension: 6.3 kN per chain
« Reply #34907 on: January 04, 2011, 05:48:09 PM »
Books? We don't read no stinkin' books here at da bar!
Offline Brown Bomber
« Reply #34908 on: January 04, 2011, 05:53:16 PM »
Keep the Shiny side up!
1987 ZG1000 "King Crimson"
1972 CB750K2 "Stout"
1976 CB500T "Witch's Promise"
1973 CL450K5 Cafe Project
        Vito Corleone
« Reply #34909 on: January 04, 2011, 05:54:43 PM »
dano dead
Offline Frankencake
  • Yesssssss,
  • "I like the old junk"
« Reply #34910 on: January 04, 2011, 05:56:00 PM »
Take the old one off, put new one. done ;D
Installation is the reverse of removal.
333:  Think "Shakeweight".
« Reply #34911 on: January 04, 2011, 06:00:23 PM »
dano dead
Gerry Rafferty to today........Baker street was a great timeless song....
« Reply #34912 on: January 04, 2011, 06:05:21 PM »
kodachrome dead too
Offline burmashave
  • Forum Immoderator
    • burmashave.net
« Reply #34913 on: January 04, 2011, 06:35:39 PM »
Ha ha ha ha. I'm gonna use that. Do I need to cite you as a reference?
Quote from: SOHC Digger, RIP
'77 CB750k
« Reply #34914 on: January 04, 2011, 06:58:28 PM »
Yes, and royalties shall be mailed to Dukiedook for each public use.
« Reply #34915 on: January 04, 2011, 08:17:55 PM »
   Dukie is..........
Offline FrankenFrankenstuff
    • FrankenBike Stuff Store
« Reply #34916 on: January 04, 2011, 08:22:57 PM »
The Duke of  Dooookie ness
« Reply #34917 on: January 04, 2011, 08:25:32 PM »
The Dukester!
« Reply #34918 on: January 04, 2011, 08:30:45 PM »
Dook O Matic
Offline SOHC Digger
  • I'm not an
« Reply #34919 on: January 04, 2011, 08:34:20 PM »
Robert E. Lee and the way the civil war REALLY ended...
« Reply #34920 on: January 04, 2011, 08:36:44 PM »
Dookalater....
Offline burmashave
  • Forum Immoderator
    • burmashave.net
« Reply #34921 on: January 04, 2011, 08:52:49 PM »
Dookmeister
'77 CB750k
Offline burmashave
  • Forum Immoderator
    • burmashave.net
« Reply #34922 on: January 04, 2011, 08:53:17 PM »
Dooktater
'77 CB750k
« Reply #34923 on: January 04, 2011, 09:00:51 PM »
Sir Dukie!
« Reply #34924 on: January 04, 2011, 09:20:17 PM »
Duke of Dook.
Count Dookoo.
Mr. Dukiedook, killin' zombies for a livin'.  ;D
