Hey guys
In the middle of reassembly of my CB550. The motor has been sealed up and done for awhile and we're getting everything back onto the frame.
We threw on the Kickstarter and decided to see if it was functioning. The Kickstarter moves extremely easily and seems to be turning the drive sprocket on the other side of the engine. Not sure what could be causing this, hoping someone else has run into this.
A couple details that may or may not be connected:
1) The engine was stripped down to nothing and reassembled
2) The clutch has been totally replace, the Clymer manual was a bit odd on this install, I had no idea how far to tighten those 4 bolts that go through everything, could this be affecting anything?
3) The clutch cable has not been reinstalled, so I cannot disengage the clutch
Any thoughts? Really really hoping I don't need to totally dissemble and split the cases again
