I was on a big ride ride on my cb750a. Have k4 carb and cam. Was running ok, no missing etc. Running ram air over the rubber stacks. Have dyna s. It seemed to go to 2,3 cyl and limped home. Cleaned carbs, raised clip 2nd from top. Did valve clearances. Checked ignition timing. Replaced leads . New plugs. Flow balanced carbs.
Now, it fires up on full choke...ONLY.I've cleaned the carbs twice. Tried air /flow 1 turn out , 3+ no difference.
Could it be faulty dyna s? 6000ml old. Coils 5ohm dyna , tested perfect. How to test a dyna s?
Or is it definitely carbs, what to do next?
Thanks@!!!
