Author Topic: Cb750 / cb77 float bowl  (Read 671 times)
Offline Willythepooh
« on: September 28, 2018, 03:46:59 AM »
Anyone have a spare bowl ? I damaged mine trying to get a broken screw out.
Re: Cb750 / cb77 float bowl
« Reply #1 on: September 28, 2018, 10:18:12 AM »
which one did you damage?  Do you have PD carbs or an earlier set?
The PD carbs have 3 different bowls.
#1, #2 and #3 are different from each other.
(3&4 are the same)
And since you are in the UK, it might be best to post over on the UK site... ;)
« Reply #2 on: September 28, 2018, 01:23:54 PM »
It’s a cb750 K4 with Keihin carbs.
All bowls are the same shape, just the drain screws in different orientation.
It’s number 4 on the right hand side that I damaged and I have posted on the UK forum also.
