Author Topic: This should get people talking Mike Rieck  (Read 3268 times)
  • Moderator
« on: September 29, 2018, 11:11:45 AM »
I found this on Facebook and thought, never in a million years as did several others but the guy couldn't remember who built it.
This is where Mike Rieck needs to come in, but have a read of this first and I'll post a picture.
This is for the ole Honda 750 Four fans (single overhead cam version) circa 1969/1978. I do not know where this bike is today but i had the opportunity to ride it one weekend in 1987 at the Piedmont Dragway, NC while an IDBA venue. Bike was owned and riden by a gentleman named Bob Jones of Whitakers, NC.
As i know to be true, the bike was the quickest naturaly asperated on carbeurators and gasoline single overhead cam 750 four ever modified and built to drag race at the time. The cylinder head was so highly modified that it had chevrolet 2.02 intake valves with improved intake tracks that effectively flattened out the valve angle. Made it a pretty good 1080cc air pump as i remember. Popular body by "Tracy" with a custom paint livery named "BLACK GOLD". If i remember correctly the bike ran 5.90's in the 1/8th mile @118mph on average. Bob raced under the name J&L Racing as he had a partner. Bob was and may still be good friends with Ron Ayers of Greenville, NC. Ron Ayers was riding a Pro Stock last i remember.
Re: This should get people talking Mike Rieck
« Reply #1 on: September 29, 2018, 11:46:06 AM »
Cam?
  • Moderator
« Reply #2 on: September 29, 2018, 11:52:42 AM »
Cam?
No idea PeWe, it was the size of the inlet valve that had everyone doubting it.
  • Moderator
« Reply #3 on: September 29, 2018, 11:54:55 AM »
The above picture is a stock head with the vernier set at 2.02 but in mm.
  • Moderator
« Reply #4 on: September 29, 2018, 11:58:21 AM »
It was eventually found that the head was far from stock and had been converted by a very good friend of Mike's.
Offline Cb750 Racer
« Reply #5 on: September 29, 2018, 12:03:08 PM »
51mm intake valves....  I'd love to see it
Turbo Billet Block cb750
1975 Honda CB400f
1972 Suzuki GT750J
1984 Kawasaki GPZ900 Mr.Turbo Top Gun build
2002 Suzuki Bandit 1200 Turbo
1979 Honda CBX
1990 Mr.Turbo Kawasaki ZX11
And Dozens More...
  • Moderator
« Reply #6 on: September 29, 2018, 12:24:12 PM »
I've not seen it either and even I thought it impossible until the guy remembered and told us who did it.
Offline kmb69
« Reply #7 on: September 29, 2018, 12:40:31 PM »
It is impossible. Turns out, Rick Stetson purportedly used a 2.02 Chevy valve as a "blank". It was machined down to something less than 40mm.
But it had a 2.02 Chevy valve in it!  ;)  ;D  :o  ::)
« Reply #8 on: September 29, 2018, 01:30:59 PM »
Well they are cheap 10 bux for a stainless one from Speedway.
But the .34 stem is a concern, that is just under 9mm.. a tad big.
 I am sure there are closer choices..
Offline kmb69
« Reply #9 on: September 29, 2018, 01:37:59 PM »
Yep. But that's the story they're sticking to.  ???
« Reply #10 on: September 29, 2018, 01:46:59 PM »
After the second dragrace in the world, the BS stories started........
 Maybe even earlier than that..
  • Moderator
« Reply #11 on: September 29, 2018, 02:43:24 PM »
Keith and Frank, I guess anything is possible for a good machinist if the blank is to big for the job, even the stem could have been turned down to CB size.
We will have to wait until Mike see's this and hopefully he can ask Rick.
The guy in the facebook post did say that the head had been drastically modified, valve angles, the lot.
« Reply #12 on: September 29, 2018, 04:01:32 PM »
 Whoa, whoa , whoa fellas....pump the brakes. ;D ;D ;D
 I think Rick originally used turned down GM valves....I thought the were Pontiac pieces but it is hard to remember. I am sure the stem OD was reduced too. I think Volkswagon valve springs were used.
 It would be physically impossible to fit a 2" valve in a CB head....no matter what the valve angle is changed to. Plus a max bore is like 74mm....why would you need a 2" intake valve?
 Anyway....Rick switched to titanium valves towards the end of development and those were coming from either Russ Sr or Byron. I know valve to valve was stupid close....something just under .030 or so. A light valve was needed as earlier spring pressure was causing the spring base to break into the port. Even with the Ti valves he used a top hat set up under the spring base.
 The intake ports were straight and I don't know what the valve angle was compared to stock...maybe a 1 degree shift.
 The cam profile was crazy and required major valve sinking.
Offline kmb69
« Reply #13 on: September 29, 2018, 04:03:05 PM »
2.02 is IMPOSSIBLE! I don't care how much you change the valve angle! The valve would have to be straight up and down - right through the cam!
Just spoke with Mike. He is out of town visiting family this weekend. But he did say he would try to nail it down with Rick and let us know what they were doing at the time.
Sorry, did not realize Mike had posted.
I'm guessing 38mm, 1.496", 40mm MAX.
« Last Edit: September 29, 2018, 04:05:33 PM by kmb69 »
« Reply #14 on: September 29, 2018, 04:07:43 PM »
 Also...the entire package was very fragile. After a weekend meet the valve job was all over the place and everything had to be gone over. I saw trans shafts so twisted they belonged in a pretzel bowl next to a brew. He used CR750 primary chains and they were surprisingly tough. I don't know exact CR....I'd guess around 15:1 or so.
« Last Edit: September 29, 2018, 06:02:04 PM by MRieck »
« Reply #15 on: September 29, 2018, 04:10:20 PM »
38mm sounds about right to me.
  • Moderator
« Reply #16 on: September 29, 2018, 04:56:20 PM »
Cheers Mike, that will do fine by way of an explanation, you are the tops my friend.
« Reply #17 on: September 29, 2018, 05:32:20 PM »
You know you are most welcome brother.
Offline kmb69
« Reply #18 on: September 29, 2018, 05:55:51 PM »
Also...the entire package was very fragile. After a weekend meet the valve job was all over place and everything had to be gone over. I saw trans shafts so twisted they belonged in a pretzel bowl next to a brew. He used CR750 primary chains and they were surprisingly tough. I don't know exact CR....I'd guess around 15:1 or so.
Not surprised at all to hear that. "Fragile" might be an understatement!
There is relatively little head material left at 38mm much less sunk deep for a big cam.
Thanks for clarifying Mike. You da go to #1 head man!
