Author Topic: Blinkers Blow Main Fuse  (Read 841 times)
Offline Kirin36
« on: September 30, 2018, 06:30:58 PM »
I have an odd issue with my cb750.. When I hit the blinkers it blows the main fuse, leaving me stranded. What should I look for?
I have changed the main fuse to a blade style, but I can't see that being the issue
Offline evinrude7
  • not a kung-fu
  • something to hüsker
Re: Blinkers Blow Main Fuse
« Reply #1 on: September 30, 2018, 08:02:33 PM »
Check all the connections for the wires that run the blinkers.  Probably have a short.
Sent from my LG-H871 using Tapatalk
cb750 k6 - ugly
« Reply #2 on: September 30, 2018, 10:32:50 PM »
See if the wire harness is chafing on the steering neck.
Offline calj737
  • I refuse...
« Reply #3 on: October 01, 2018, 03:35:07 AM »
Did you happen to change the stock bars or controls? These are the leading causes to create the symptoms listed above.
Offline Little_Phil
« Reply #4 on: October 01, 2018, 08:06:20 AM »
If it happens on left and right, look for common components. Handlebar switch?
Offline Kirin36
« Reply #5 on: October 01, 2018, 12:44:14 PM »
They are definitely replaced. I will dig into this and the wires today and let you guys know what I find
