Author Topic: Need a quick physical measurement on a CB750  (Read 1941 times)
Offline greenjeans
  • 1972 CB750K2
« on: October 02, 2018, 08:29:11 AM »
Is there anyone in CB land that can measure the outer distance between the rear shock mounting bolts.   Need the measurement from the outside edge of the stud/bolt to the outside of the other stud/bolt.   The one day I didn't ride mine.
Offline kmb69
Re: Need a quick physical measurement on a CB750
« Reply #1 on: October 02, 2018, 09:02:45 AM »
From the ends of the threads or outside shoulder to outside shoulder?
Offline greenjeans
  • 1972 CB750K2
« Reply #2 on: October 02, 2018, 09:22:22 AM »
the outermost portion of the bolts/studs
Thanksk!
« Reply #3 on: October 02, 2018, 10:06:22 AM »
Just measure both.
 I got a 74 and 78 outside but it's passing out there , can't measure till later..
Offline kmb69
« Reply #4 on: October 02, 2018, 11:36:16 AM »
Thanksk!
Including the threads or not??? I interpret outermost as the threaded end too. You too, Keith?
Yep.
Measurements with calipers on frame CB750-1015411:
Outside to outside (threads included): 322.5mm
Outside shoulder to outside shoulder: 294mm
Inside shoulder to inside shoulder: 241.5mm
There are manufacturing tolerances that only Honda knows.
And later frames had longer threads.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #5 on: October 02, 2018, 04:05:03 PM »
Thanksk!
Yep.
And later frames had longer threads. shoulders and a wider swingarm
[/color]
FTFY  ;)
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #6 on: October 02, 2018, 04:20:32 PM »
 Not longer shoulders.. they should be same length.
 It's wider shoulder overall width, and longer wider swingarm.
« Reply #7 on: October 02, 2018, 05:14:38 PM »
When I say "shoulder" I guess I should have said "base". The "base" of the upper stud is 10mm wider on the left side on the later models to push the top of the shock out to match the extra width of the later swingarm.
TAMTF...
Wilbur
Projects:
Offline kmb69
« Reply #8 on: October 02, 2018, 05:58:11 PM »
Thanksk!
Yep.
[/color]
FTFY  ;)
My statement was accurate. Honda lengthened the threads 5mm on the K2 when the wrap-around bumper (hand rail) was implemented.
Pretty sure the wider frame/swingarm was not implemented until 75 on F's and 77 on K's.
I provided the frame number from which the measurements were taken for specificity.  ;)
« Last Edit: October 02, 2018, 06:00:37 PM by kmb69 »
« Reply #9 on: October 02, 2018, 06:21:36 PM »
No, I think the change was made in '77 for both K and F models.
Offline kmb69
« Reply #10 on: October 02, 2018, 06:36:36 PM »
You may be correct. I was going by the axle part number changes. But both swingarm part numbers changed in 77.
