SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Leaky tachometer ouput
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Leaky tachometer ouput (Read 872 times)
70CB750
Labor omnia vincit improbus.
Really Old Timer ...
Northern Virginia
on:
October 07, 2018, 05:34:09 pm »
On the valve cover.
I used just a generic o ring there, but it did not work so well so i found a seal that belongs there - by the part number.
It still leaks, any tricks to it?
Not sure it matters but the engine is 78SS CB750.
Logged
jgger
Master
Re: Leaky tachometer ouput
Reply #1 on:
October 07, 2018, 05:38:15 pm »
Is your oil breather tube clear? Just a thought.
Logged
"The SOHC4 uses a computer located about 2-3 ft above the seat. Those sometimes need additional programming." -stolen from Two Tired
The difference between an ass kisser and brown noser is merely depth perception. Stolen from RAFster122s
70CB750
Northern Virginia
Reply #2 on:
October 07, 2018, 05:45:07 pm »
Good point, I will check.
Logged
spotty
Master
cb750....for when a Vmax is just too much bike
Reply #3 on:
October 07, 2018, 05:48:54 pm »
get rid of the tacho, epoxy a coin over the hole...sorted, well it sorted it on my old 750 anyway but that didn't have a speedo either
Logged
i blame Terry
ekpent
To many bikes-but lookin' for more
Reply #4 on:
October 07, 2018, 06:12:02 pm »
Did you seat the seal in well with a socket a little smaller then the fitting hole ? Couple light taps with a small hammer.
Logged
JerryWayneCattle
Full Member
Reply #5 on:
October 07, 2018, 08:35:10 pm »
Make sure there isn't an old o-ring still deep in there. PO of my '74 CB750 had the correct seal AND an o-ring in it. He might have not even known. It held the cable out and didn't let it seat correctly. I bought a new one that fits a DOHC 750. Read on this site that they fit better.
Sent from my SM-N920T using Tapatalk
Logged
PeWe
Bike almost back to the 70's 2015
Reply #6 on:
October 07, 2018, 09:56:48 pm »
Correct oil seal will not leak. If hammer too hard the bottom of the cover can crack, alu chunks fall into the cam holder. Especially when removing the old seal with tools from the outside. Somehow, I know
Frame kit is good in that kind of situation.
Logged
CB750 K6-76 1005cc JMR Billet block.
CB750 K2 -1975 build thread
Marks78
Enthusiast
Reply #7 on:
October 08, 2018, 08:26:18 am »
I'm not positive (as I can't find the reference) but it seems like HondaMan recommends using the tach seal from a double overhead cam Honda as a viable alternative. The DOHC seal is just a tad bigger, so it seals better. Best of luck!
Logged
Current Stable:
1978 CB750K
1982 XT200J
1982 XJ1100 Maxim
1985 V30 Magna
1998 VT1100 Spirit
2006 GoldWing
evanphi
Apparently I'm an
Old Timer
Rhonda the Basket Case
Reply #8 on:
October 09, 2018, 07:28:34 am »
Mine leaks also, and also with a properly seated new rubber seal. I did just a few wraps of PTFE tape on the end of the tach cable and that snugged it up perfectly. No more leaking.
Logged
--Evan
1975 CB750K "Rhonda"
70CB750
Northern Virginia
Reply #9 on:
October 29, 2018, 05:06:00 am »
Well, turns out if was a false flag. The tachometer cable sheathing was cracked quite a bit and the oil was leaking from there.
Luckily I spotted it before digging out the seal
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
