I've got a weird one. I have 1976 cb550 that has been 'brat built.' After a long a troubled relationship with the builder, I got the bike back with some weird problems.
Some background: he installed an all new harness using an M-Unit, that's pretty much set up like the attached diagram. there is a Dyna electronic ignition attached to the original coils (which read 5 ohms). It has new plug boots and wires. The kill switch is gone, it's using a new 12 v antigravity battery, an LED headlight. LED signals, and LED tail light.
here is where it gets weird. Brought it home, and kicked over and started perfect. next day take it out for a ride and, after filling up, feels like it's loosing power and then it looses power. Was able to kick it over a couple of times and then nothing, including all of the lights.
Next day, i test it out and I get spark on the 2,3 but nothing on the 1,4. I check out the harness and find some loos wires that may have shorted, so i cover them and wiggles some stuff around, and all the electric starts to work (lights, horn, signals...) I also pulled the carbs to see if they were gunked from sitting god-knows how long outside, covered or uncovered, in the rain and heat of the summer..... Carbs look fine, albeit I only went into the float bowls.
Next day, I get no sparks anywhere. the rest of the electric still works.
I checked the 1,4 ignition wire (while not attached to the coils) with a test light. Pushed the lobe forward and rotated the crank and got nothing.
Now here is the weird part. See the pic- the 'black' wires on the coils have been soldered together. My guess is that this was necessary to eliminate the kill switch. However, i'm confused as to how the coils are getting their power? (or they aren't and that's why i'm not getting a spark). All the wiring diagrams (both stock wiring and with the m unit) show that each coil has 2 plug wires, 1 circuit wire to the ignition and one 'power' wire. Also, the soldered potion of the coils were like this when i got all 4 cylinders running, so ockham's razor, this isn't it.
So confused!
Thanks for the help.
