Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
Is it as simple as just using a y splitter?
I didn't have any luck trying to affix an aftermarket single-out petcock to my 550 tank (the threads on the petcock and bung weren't synched appropriately to allow the face of the petcock with the on/off/reserve lever to be oriented correctly - never tried a 500 petcock). I did have a "Y" splitter affixed to it that seemed to flow ok. Ended up ditching that solution and found a NOS 550 petcock. Pricey, but works as designed:https://www.ebay.com/itm/Honda-NOS-petcock-CB-550K-550F-550-F-K-CB550-1975-76-part-16950-374-671/232953858495?epid=1023298215&hash=item363d21c9bf:g:Ri4AAOSw~cVZ0r4a:sc:USPSFirstClass!23060!US!-1
Wait, that petcock doesn’t have an independently spinning coupler nut like most petcocks? Normally you hold the petcock in the orientation you want and then spin the nut. They don’t machine the petcock and tank bung threads to make the petcock land in the right orientation. That would take a lot of setup and thinking ahead when the petcocks with independently spinning nuts already exist.
