Author Topic: Street Stroker?  (Read 12224 times)
Online Don R
Street Stroker?
« on: October 12, 2018, 09:51:07 AM »
  Can an 1124cc welded stroker be used on the street?  Asking for a friend.
Online gschuld
Re: Street Stroker?
« Reply #1 on: October 12, 2018, 11:54:24 AM »
That’s a fine question...
I’ve been pondering the same question myself for a while.  From what I’ve come to assume after a lengthy search is that welded stroker cranks made up in the 70s are unlikely to pass a magniflux text for cracks. I had one sent to Jay last year and it failed badly.  I’ve heard of plenty of others with the same experience.
I’m not up on these things, but I’ve been led to believe that the process has improved significantly at the higher end of the spectrum, like in top shops such as Marine Crankshaft in Ca.  They do welded stroker cranks for Big power drag bikes regularly.  It would be a stretch to say that a top quality new welded stroker crank offers the long term reliability as a factory stroke crank however.
But if someone has a welded stroker crank done many years ago in an older assembled big bore engine that they want to run on the street, I’d strongly recommend a tear down and having the crank magnifluxed by a top crank guy.  Even then (for a vintage welded crank) I’d be concerned based on their reputation as a time bomb.
I can’t think of a single person currently running an older welded stoked crank in a cb750.  The triple is going to use the original cranks though, but I recall 2 of the 3 were sent to a marine crank for some repair (don’t now what).  These cranks were very unique with their long drive snouts so they aren’t fair to compare with much of anything.
George
Online Don R
Re: Street Stroker?
« Reply #2 on: October 12, 2018, 12:14:24 PM »
 I had mine magged at a friends shop, when I returned the guy said You didn't tell me it's a welded stroker! Every weld shows up as a line. Then he added, but none were sharp like a crack. They were all soft and fuzzy. He said give me $10 and get out of here.
Online Don R
Re: Street Stroker?
« Reply #3 on: October 12, 2018, 12:33:44 PM »
 I'm taking the 1124 back apart to find an oil leak and check out things I neglected to do in my previous rush to get it together. I'm considering a swap to a low mileage 78 super Sport crankcase and a back cut F trans I had done. Along with a 78 drive hub that will make a little more room for the 5" slick to chain clearance even with the 530 chain.
Re: Street Stroker?
« Reply #4 on: October 12, 2018, 04:36:14 PM »
I'm thinking of a 5mm welded stroker for the "final" engine for my CB. 72mm pistons. It won't get a lot of use. Marine does the best job you can get for a welded crank. They straightened, repaired rod journals (including the oiling holes) that were so far out of whack I couldn't believe.
 Maybe a group buy on some billet strokers. ;D
Re: Street Stroker?
« Reply #5 on: October 12, 2018, 04:57:29 PM »
I ran across RPE racing @ Australia. Insane big bores and billet 70mm cranks machined for cb750. Can't seem to dial their number correctly to see how much how much is. They have short sohc rods on eBay for it right now. Has anyone  tried The RPE billet crank yet?
« Last Edit: October 12, 2018, 05:09:44 PM by Tracksnblades1 »
Re: Street Stroker?
« Reply #6 on: October 12, 2018, 05:14:22 PM »
I will be interested going in on the billet buy, if I don't find out how to dial RPE successfully.
Offline T1m32sh1n3
Re: Street Stroker?
« Reply #7 on: October 12, 2018, 05:31:46 PM »
I thought RPE closed doors @ their shop?
Re: Street Stroker?
« Reply #8 on: October 12, 2018, 05:36:12 PM »
Alright. Are you located in the USA? What you can expect from Marine......that and a good size bill. ;D
http://www.marinecrankshaftinc.com/billets/Hayabusa-73mm-stroker.jpg
http://www.marinecrankshaftinc.com/billets/Hayabusa73mm-stroker.jpg
« Last Edit: October 12, 2018, 05:38:36 PM by MRieck »
Re: Street Stroker?
« Reply #9 on: October 12, 2018, 05:57:49 PM »
I have been in contact with him through this ad. This is how I found out they used a 70mm billet in their 1340 build. Dialed 011 61 2  plus number @ website. Just recording. Like to talk to the person before the $2,650 -  2750 for his billet crank changes hands. A few clearance questions you know.
Thanks for the closing heads up.
https://www.ebay.com/itm/Honda-CB-750-69-78-SOHC-Conrod-suit-Boldor-Crankshaft-stroker/273483991512
« Last Edit: October 12, 2018, 06:38:33 PM by Tracksnblades1 »
Re: Street Stroker?
« Reply #10 on: October 12, 2018, 06:09:39 PM »
Em Busa Billets look like a Mechanic's Monet'......
Re: Street Stroker?
« Reply #11 on: October 12, 2018, 06:20:41 PM »
I have handled several of those busa cranks....they are awesome brother.
Re: Street Stroker?
« Reply #12 on: October 12, 2018, 08:16:22 PM »
Is that a 72mm bore 1/4" stroke (old RC stuff)?
Re: Street Stroker?
« Reply #13 on: October 13, 2018, 02:48:03 PM »
Illinois..... I'm in for a group buy....It would be great if we could pick our own stroke in that buy...
Re: Street Stroker?
« Reply #14 on: October 13, 2018, 03:40:41 PM »
I imagine getting the stroke you want is just a few keystrokes. With a billet crankshaft  7mm would be awesome but you would need a spacer plate IMO. Moving the wrist pin and short  rods wouldn't be a good idea with that increase.
Online Don R
Re: Street Stroker?
« Reply #15 on: October 13, 2018, 07:10:26 PM »
 I measured it once and lost the number sheet. I'll re-check it when I'm in there soon. I'm thinking 5mm. Everyone called a 1200 back in the Day. The PO's kids even argued with me about it.
« Last Edit: October 13, 2018, 07:17:47 PM by Don R »
Online Don R
Re: Street Stroker?
« Reply #16 on: October 13, 2018, 07:13:52 PM »
Online gschuld
Re: Street Stroker?
« Reply #17 on: October 13, 2018, 07:19:58 PM »
FWIW, When MEC built his dohc crank stroker race motor for his Elgi road racer, he had Buzz order up a set of JE 71.25 flat top pistons with a 3mm reduced compression height. Pics below.  They were quite lightweight as well at 226 grams WITH rings and pin.
A 70mm stroke crank (7mm stroke increase) would need only a rather thick copper base gasket to work.  The head only being lifted 1mm up would do nothing worth noting to alter the cam chain distance, cylinder stud length, etc.
That seems to be the idea route.  Other than those darn skinny rings🙄
George
« Last Edit: January 26, 2022, 04:26:25 AM by gschuld »
Offline bear
  • Leeton in Australia
Re: Street Stroker?
« Reply #18 on: October 14, 2018, 02:57:10 AM »
Yep, your right not a good idea at all. I have actually used slightly longer rods.
Brian
« Last Edit: October 14, 2018, 03:05:28 AM by bear »
Online gschuld
Re: Street Stroker?
« Reply #19 on: October 14, 2018, 05:19:15 AM »
Certainly the rod stroke ratio is improved by a stroker crank with longer rods to help match the original ratio.  Conversely, using shorter rods with the longer stroke makes the ratio significantly wider.
Using a stroker crank along with factory length high quality rods, such as Carrillo rods, along with very lightweight pistons to reduce some of the strain on those rods, seems to be a reasonable compromise.  No?
George
Re: Street Stroker?
« Reply #20 on: October 14, 2018, 10:34:09 AM »
 I have just heard longer rods Increase dwell of the piston.
 A local builder remarked on how much difference it made in his XXL 350 ..aka 490 flattracker.
 Hp jumped 10 or 15 percent, he make more than his CR 450, and even better, more down low.
 50 hp at the rear wheel , in a 225 lb wet Champion frame.
So I guess getting a longer  cam chain, and stroker plate , May help..
Re: Street Stroker?
« Reply #21 on: October 14, 2018, 11:29:36 AM »
Yep, I like long rods in SBCs too.
Also water and some women follow a longer rod.😎 Surveyors Joke.
« Last Edit: October 14, 2018, 12:21:06 PM by Tracksnblades1 »
Re: Street Stroker?
« Reply #22 on: October 14, 2018, 11:54:32 AM »
George
George, Are you reigniting the late great Smokey Yunick debate? I'm thinking the current ProStocks have been moving down from that magic 1.8 ratio of yesterday.
« Last Edit: October 14, 2018, 12:04:35 PM by Tracksnblades1 »
Online gschuld
Re: Street Stroker?
« Reply #23 on: October 14, 2018, 12:45:56 PM »
George
I’m not trying to reignite anyone’s debate(although I have great respect for old Smokey😉)  RC Engineering’s method was to do a 6mm over weld up stroker crank using dark ages techniques, then combining that with 3mm shorter than stock Golden rods.  It surely made a less than ideal situation.
I’ve read a number of articles from well respected engine builders on the rod/stroke subject.  Most agree the longer rod offers less overall stress on the piston/walls with its slightly more vertical focused force on the pistons.  But often there is assumed to be a point of diminishing returns.
As in, once you reach a rod/stroke ratio of X, there is little to nothing to gain from going longer on the rods as compromises in other things start to make up any added gain.  Most of the reference material I have read on the subject were related to V8 auto engines, so it’s just a general situation.  What that tip over point is for out sohc4s, no idea.  Perhaps what is considered reasonable for an all out race motor is different from a big street gas compression registered road bike?  The race motor will undoubtedly put more stress on the rotating assembly with the extra power used and situation(drag racing, road racing, land speed). All of these are a lot harder on an engine than driving on the street.  Unless someone has a death wish anyway😳
If I were set out to race a big bore stroker engine in a very demanding situation (I can’t think of anything more severe than Bear’s heavy total all up weight sidecar road racer😳) then absolutely going with a set of 1100f rods(1.5mm over stock) makes total sense as it puts the rod/stroke ratio back to reasonably close to factory.
I have a motor that was drag raced for many years in the late 70s through the early 90s with an RC welded stroker crank and factory length rods with a stroker plate and standard compression height RC 73mm H/C Arias pistons.  Lots and lots of 9.xx second passes on a D&K lay down frame(it was owned by David Morgan from St Louis at the time). That crank may very well have been an anomaly for lasting as long as it did.  Reportedly it was retired from service because of fear of it being tired rather than because it failed.
I’m not convinced of anything on the subject, but I’m interested in hearing more opinions about it.
George
Re: Street Stroker?
« Reply #24 on: October 14, 2018, 01:51:13 PM »
A couple things that sway me towards longer rods for a given stroke will reduce piston speed, potentially reducing friction and piston/ring wear. Plus as Frank mentions will increase dwell at TDC holding compression longer aiding combustion.
Not a 750 situation for me but I'm looking at building a big bore, short stroke, long rod engine for roadracing Decreased combustion chamber volume and increased dwell needs less spark lead.
There are some disadvantages naturally but in the middleweight engines Honda used rod ratios fairly close to modern Japanese sportbikes.
« Last Edit: October 14, 2018, 02:32:25 PM by bwaller »
