Author Topic: Street Stroker?  (Read 9265 times)
Offline kmb69
Re: Street Stroker?
« Reply #50 on: October 15, 2018, 05:10:07 pm »
I don't think it's a matter of suitability. I think the process of welding cranks itself for these applications is flawed.
But having a large hot reciprocating mass disintegrate between my nether regions a couple of times may have clouded my judgment .  ;D
Brian
Imagine that!  :D
Offline bear
  • Leeton in Australia
Re: Street Stroker?
« Reply #51 on: October 15, 2018, 05:43:27 pm »
I could understand that....😳.  Out of curiosity what timespan were you running and breaking welded cranks?
George
We did three cranks over two seasons and to be honest only one ventilated.
They all seemed to fail on the overrun though.
Brian
Offline bear
Re: Street Stroker?
« Reply #52 on: October 15, 2018, 05:45:49 pm »
how did your nether regions hold up?
Not well these day's..... I put it down to that earlier wear and tear.  :D
Re: Street Stroker?
« Reply #53 on: October 15, 2018, 08:07:51 pm »
Sure, but in the case of a 69mm stroke CB750 engine, is there much functional difference between a 1.68 and a 1.70 rod ratio?  That’s it between a factory length rod an an 1100f rod in that engine.
George
No there's not George but in my case these where the two options that I had .
And many years ago in the back block's of Australia those two options (factory rods) where the only one's available.
The std 750 rods or the M4 1100 rods that where stronger had 17mm pins and where a little closer to optimal length.
Brian
Bear Brian,
Do you still run the DOHC crank, cb1100 rods, and HYVO,  or have you moved on?
Thanks
Re: Street Stroker?
« Reply #54 on: October 15, 2018, 11:42:25 pm »
 I suppose a next step would be to contact Scat/Bryant/Lunati/ whoever, to ask about the requirements for a run of cranks.  With modern cnc I'd think the design part would involve measuring a stock one or a properly modified one and determining the case clearance issues for the rods and weights. My case is clearanced a lot but it's swinging aluminum MTC rods too.
Offline bear
Re: Street Stroker?
« Reply #55 on: October 16, 2018, 12:05:23 am »
Bear Brian,
Thanks
I don't run them these days but the two complete motor's I still have use that configuration.
And yes I have moved............to retirement, old age and sanility. ;D
Brian
« Last Edit: October 16, 2018, 12:55:21 pm by bear »
Re: Street Stroker?
« Reply #56 on: October 16, 2018, 04:11:48 am »
Has the counterweights OD been modified on your welded stroker?
Re: Street Stroker?
« Reply #57 on: October 16, 2018, 04:19:14 am »
And yes I have moved............to retirement, old age and salinity. ;D
Brian
[/quote]
😆 A little saltiness doesn't hurt, just have to stay away from the slow cognitive degenerative stuff.😎
« Last Edit: October 16, 2018, 04:37:26 am by Tracksnblades1 »
Offline gschuld
Re: Street Stroker?
« Reply #58 on: October 16, 2018, 12:07:46 pm »
I can’t answer for Don about his vintage welded crank, but in the case of the welded stroker cranks Marine Crankshaft does, they do not alter the counterweights.  It can be balanced as is.
George
Offline bear
Re: Street Stroker?
« Reply #59 on: October 16, 2018, 12:54:05 pm »
And yes I have moved............to retirement, old age and salinity senility ;D    ( there you go example A) :o
Brian
[/quote]
« Last Edit: October 16, 2018, 12:55:57 pm by bear »
Re: Street Stroker?
« Reply #60 on: October 16, 2018, 10:13:37 pm »
Brian
[/quote]
Example A...?  SIRI  does that crap to me all the time. She changes what I want before I finish typing. That's My Story and I'm sticking to It...😎
« Last Edit: October 16, 2018, 10:20:59 pm by Tracksnblades1 »
Re: Street Stroker?
« Reply #61 on: October 16, 2018, 10:16:53 pm »
George
Thanks George that's good to know. Has your cases been clearances too. Or do you run steel rods?
Re: Street Stroker?
« Reply #62 on: October 17, 2018, 10:30:36 pm »
I don't believe so, the case is only clearanced for the MTC aluminum rods.
« Last Edit: October 19, 2018, 06:33:45 am by Don R »
Re: Street Stroker?
« Reply #63 on: October 21, 2018, 12:00:42 am »
 I'm intrigued by the splined end on the 900 crank. When I get my car engine out of the machine shop, assuming I'm not broke I may need to grab a few parts off of ebay and pay a visit to some local machinist crazies I know.  I was offered a cb900 engine that the cam chain had eaten a slot into but thought I had enough junk already. lol.
