Author Topic: I built a VAPOR BLASTER for $1300  (Read 3238 times)
Offline bochnak
    • How-To Motorcycle Repair Blog
« on: October 15, 2018, 06:46:44 AM »
I converted my HF blast cab into a vapor blaster. I've always wanted to have this process available to me, however the machines are expensive!
I have plans available if anyone is interested in building there own:
https://www.howtomotorcyclerepair.com/diyvaporblasterbuildplans/
-Matt
Offline pjlogue
Re: I built a VAPOR BLASTER for $1300
« Reply #1 on: October 15, 2018, 06:54:06 AM »
I too built one using the HF blast cabinet.  I just use an open bucket at the bottom and make sure the ratio of beads to water is that it gives a slurry when mixed.  Works great and was quite cheap to make.
If you keep the media clean and use distilled water it greatly reduces flash rust on steal/iron parts.
-P.
Offline kmb69
« Reply #2 on: October 15, 2018, 07:18:47 AM »
Several FREE ones available if you Google: "diy vapor blasting"
Offline bochnak
« Reply #3 on: October 15, 2018, 07:36:11 AM »
I've googled that for hours. There is a lack of detail (part list) and most use pool pumps that fail.
Offline bochnak
« Reply #4 on: October 15, 2018, 07:36:46 AM »
Thanks for that info.
Offline pjlogue
« Reply #5 on: October 15, 2018, 08:42:36 AM »
If you do multiple parts and want to reduce flash rust, you can keep a bucket of distilled, boiled water near the blaster.  When you finish a part just put it in the bucket.  Distilled water doesn't conduct electricity as well as tap water and boiling the distilled water further reduces the Oxygen available to rust parts.
-P.
Offline Airborne 82nd
« Reply #6 on: October 15, 2018, 09:25:06 PM »
I don't think is the place to try and sell stuff
why not just post the parts list most us could figure out how to put it together and that would help a lot of us
Offline brewsky
« Reply #7 on: October 16, 2018, 01:03:05 AM »
What is the advantage of this vs plain old soda blasting?
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline pjlogue
« Reply #8 on: October 16, 2018, 01:20:19 AM »
Several advantages.  Soda blasting will remove material all be it a very small amount.  Vapor blasting doesn't.  Vapor blasting actually peens the material and makes the material stronger and more resistant to corrosion.  Vapor blasting also deep cleans the material via the hydrostatic shock of the glass beads impact  on the material in a wet environment.  The dust from soda blasting is pretty caustic for lungs and any plants near by.  Vaporblasting isn't.  Soda blasting is a 1 shot deal.  Once the soda is used, is used up.  Glass beads can be reused.
-P.
« Reply #9 on: October 16, 2018, 02:41:59 AM »
Really good information getting all details served!
I need a bigger garage!
Offline bochnak
« Reply #10 on: October 16, 2018, 06:38:52 AM »
The part list alone won't tell you how to build it. I'm sorry, but I have spent months working on this. A 3hr video takes time and money to create. Hope you understand.
Offline kmb69
« Reply #11 on: October 16, 2018, 08:12:28 AM »
I would probably buy one at $20.00 but $50.00 seems a little steep IMHO.
Offline bochnak
« Reply #12 on: October 16, 2018, 09:06:44 AM »
This cabinet originally was setup for soda only. Even though it is supposed to be a one time use, I used it until it broke down enough to where it would not "cut" or "clean" anymore.
Advantages of soda:
  • dissolves in water, so no media gets trapped
  • removes gasket material and silicone
  • inexpensive, my setup was 300 or so
  • perfect for carb work
  • does not damage plastic or rubber
Disadvantages of soda:
  • does not remove paint well
  • does not remove corrosion
  • does not restore finish of metal
Soda blasting video:
Mods to cabinet:
Matt
Offline Scott S
« Reply #13 on: October 16, 2018, 11:46:26 AM »
 I see the vent chimney on the vapor blast cabinet; does the shop/garage get dusty?
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline bochnak
« Reply #14 on: October 16, 2018, 11:51:11 AM »
No dust. You get a mess when you do not rinse the door before opening it. In that case, use a sponge to clean up or sweep up after it dries.
My dry blast setup wasn't dusty either. Dust deputy and shop vac worked well.
Offline trigger
  • Engines built on reputation, not advertising.
« Reply #15 on: October 16, 2018, 03:44:07 PM »
-P.
Soda blasting, bead blasting or vapor blasting all remove "some" amount of base material. How much differs with each process, and of course the media type, pressure, and angle of attack.
That is a fact ! You should never vapour blast pistons as they will never be within spec  ;)
Offline Scott S
« Reply #16 on: October 20, 2018, 01:31:26 PM »
 Sent you an email.
'71 CB500 K0
'81 Yamaha XS650
