Author Topic: Winterizing the bike!  (Read 4753 times)
Offline jlh3rd
Re: Winterizing the bike!
« Reply #25 on: October 25, 2018, 04:55:03 AM »
fire hazard.....do you mean because of fumes?......and i'm not debating, i'm asking...as i did think of that.....the heater has a tip over safety, modern circuitry uses electronic switches, not contacts that open and close creating sparks. and electric motors today are much smaller, better shielded. Also, the temp is kept around 60ish so vapor pressure temp is lower...........thoughts?
Offline Airborne 82nd
« Reply #26 on: October 25, 2018, 10:37:51 AM »
kitty litter, makes sense to me, and cheap.....ok....understand, i run a small electric heater inside the zippered bike enclosure along with the battery maintainer...
      if i didn't have a girlfriend, the bike would be in my living room....
Put your bike in the living room. Get your priority's in order :D Put a cot in the zippered bike enclosure  ;D JK
Offline Deltarider
« Reply #27 on: October 25, 2018, 11:44:08 AM »
Why not take your bike in bed and keep it warm? In seriousness: they found out that the worst polluter of the air inside one's home is an inbuilt garage...
« Last Edit: October 25, 2018, 11:46:43 AM by Deltarider »
CB500K2-ED Excel black
Offline Dos
  • Owner of a cb350f
« Reply #28 on: November 16, 2018, 10:48:51 AM »
What exactly are these horror stories of leaving gas in the tank (peacock off) and carbs?
Offline Deltarider
« Reply #29 on: November 16, 2018, 11:36:20 AM »
Probably stories told by people that are ashamed they were negligent and had their bikes standing for years and years unattended. Some owners choose to drain the floatbowls every year before hibernation. Over time they can expect dried out and deteriorated O-rings, in particular the little O-rings around the main jets and the O-rings around the T-joints. Leaving gas in the carbs for too long (years) isn't good either, so we face a dilemma. What works for me is: leave gas in the floatchambers, but drain them say every two months (gas can be poured in the tank again). Then with empty floatchambers and the big Idle Adjustment Screw turned a bit loose (to fully lower the carbslides), kick the engine a few times to suck the jets dry (I hope). Closing the chokes may help to create underpressure. Then open the petcock just to refill the floatchambers. This gives me the best result: no dried out O-rings and the gas in the floatchambers doesn't have time to become nasty. Tank is full ofcourse. There's no need to store the bike with ethanolfree gas as long as the tank is full. As a matter of fact, gas that contains ethanol has quite a buffer to absorb condens, where with ethanolfree gas, there's a risk of having a little pool of water building on the bottom of the tank. Only when fuel with ethanol is left too long opposed to air in a half filled tank and then with variations in temperatures, the absorbed water might reach a level that the fuel will start to separate. Only then it can become a problem. Bear in mind that the stabilizer products (additives) are usually nothing but... alcohol, because it absorbs condens so well. Isn't that ironic?
« Last Edit: November 19, 2018, 04:52:22 AM by Deltarider »
Offline zturb0
« Reply #30 on: November 16, 2018, 02:20:21 PM »
Posters above, who ''leave the gas in the carbs''    :o
Is that alcohol free gas?
or the crappy, 10% corn gas ? :-\
76 CB400F
98 VALKYRIE
00 ZX12R
97 BANDIT 12
89 PACIFIC COAST
91 ELIMINATOR 250
Offline Dos
  • Owner of a cb350f
« Reply #31 on: November 17, 2018, 07:28:43 PM »
Yeah I don’t know because last year I put stabil in the tank, rode it around for alittle and then shut my petcock off and drained the carbs by just running it until the gas was used all up. But then come spring I found my petcock was leaking and my carbs were messed up and I had to reset the float height and it was a whole thing and I just don’t want that to happen again. Maybe I just put too much stabil?
Before that I didn’t know any better and just left the bike with gas in the tank and carbs and let it sit over the winter and it was fine.
Offline Deltarider
« Reply #32 on: November 18, 2018, 01:53:12 AM »
Rubbers dried out and shrunk.
Yeah, you're probably right there. If hibernation does not last more than 6-7 months, you'll be fine, I guess. Before the first ride in spring, I would drain the floatbowls however (and pour the gas in the tank). What I described in reply #34, is maybe overdoing it, but, say every two months, I have to be there anyway, to charge the battery and activate the shocks a couple of times.
« Last Edit: November 18, 2018, 01:57:06 AM by Deltarider »
