Author Topic: Black is black but,,,,,  (Read 4164 times)
Offline zturb0
« on: October 18, 2018, 10:01:10 AM »
Matching it exactly, is difficult.  :o
I have a few areas on the 400 frame that need addressed.
Rust removed and repainted.
Do any of you have thoughts on what  specific brand and
type of rattle can paint comes closest.
To blending in well with the factory black?
76 CB400F
98 VALKYRIE
00 ZX12R
97 BANDIT 12
89 PACIFIC COAST
91 ELIMINATOR 250
Offline SF
  • I burn gas very well
Re: Black is black but,,,,,
« Reply #1 on: October 18, 2018, 01:29:46 PM »
Start with an enamel base paint
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
rgid springer bobber project
Offline Bankerdanny
  • Endeavor to persevere
« Reply #2 on: October 18, 2018, 02:13:47 PM »
Harbor Freight sells a frame paint that is almost an exact match for the factory paint. I have used it on my GL1000, CB550, and CB750. I highly recommend it.
« Last Edit: October 18, 2018, 02:15:58 PM by Bankerdanny »
Offline beemerbum
« Reply #3 on: October 18, 2018, 03:04:43 PM »
I have used Rustoleum Appliance epoxy , black of course, on two CB 750 frames so far. No primer, only lots of sanding and cleaning
Bobarama
« Reply #4 on: October 18, 2018, 04:05:06 PM »
I use Rust-Oleum from the can with a brush.
« Reply #5 on: October 18, 2018, 04:11:03 PM »
 Bob does it dry fairly quick ? The aerosol rustoleum takes like a day go be able to handle.
« Reply #6 on: October 18, 2018, 08:47:28 PM »
 X2 on the rustoleum appliance epoxy
AwesomeCB
« Reply #7 on: October 19, 2018, 03:16:25 AM »
Also agree on Rusto App Epoxy.
Offline jlh3rd
« Reply #8 on: October 19, 2018, 03:27:27 AM »
eastwood makes a paint called under hood black. It's not a gloss, semi, or satin.
Offline zturb0
« Reply #9 on: October 19, 2018, 07:44:11 AM »
Ok, I located the H F paint locally.  ;)
However, the rust-oleum appliance brush black,
 doesn't even come up, when searchin their site.  ???
I find it in a spray can, but it says ''for indoor use''
I would like to buy both, and compare results.
Anybody know where, to buy some?   ???
76 CB400F
98 VALKYRIE
00 ZX12R
97 BANDIT 12
89 PACIFIC COAST
91 ELIMINATOR 250
Offline johans
    • corporate leather
« Reply #10 on: October 19, 2018, 09:51:37 AM »
Been using Rustoleum Professional semi - gloss black w/ great results . I spray it with a siphon cup gun .Hard as rock when cured.  Thins w/acetone . flows nice.
1978 CB750K
1976 CB750F SS
1978 CB750F
1979 Honda 400T
1979 BMW R65
1979 Kawasaki KZ400
2003 Ducati Monster 800 SIE
1988 Suzuki GSXF
Kawasaki 200 KDX
Yamaha YZ 250F
1986 Kawasaki KZ 900
Kawasaki Lakota 300 ATV
Offline Scott S
« Reply #11 on: October 19, 2018, 10:29:10 AM »
 Good old, cheap Walmart paint is good, too. Not TOO shiny. Super cheap. Easy to touch up.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline jakec
« Reply #12 on: October 23, 2018, 12:13:36 PM »
I have my engine out right now and I'm debating painting the frame, it needs it in some spots. I'm wondering though if i do a DIY spray job like with the paints suggested above (rustoleum appliance epoxy) then will it just chip and come off with the slightest knicks? Or can it be as strong as the original frame paint?
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline calj737
  • I refuse...
« Reply #13 on: October 23, 2018, 04:34:29 PM »
You need to scuff the existing paint, and then degrease it well. The "mechanical adhesion" is created by sanding/scuffing. Stick with 220 grit. Do a tidy job, and you can get a pretty result. A decent primer below (if you have rust) and it will be very durable.
Offline jakec
« Reply #14 on: November 17, 2018, 11:06:47 AM »
Any tips for degreasing? Could I use carb cleaner since I'm going to repaint anyways? Or too harsh?
I found this, is this the paint we want? It says no primer needed? I don't have any rust aside from light surface spots here and there. I don't mind priming though if it will help the paint hold up.
https://www.rustoleum.com/product-catalog/consumer-brands/specialty/appliance-epoxy-spray/
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline calj737
  • I refuse...
« Reply #15 on: November 17, 2018, 11:34:13 AM »
Don't use carb cleaner. It can leave a residue undesirable to painting. Just use Simple Green or similar. Wash it up well, and rinse it clean. A quick wipe with Acetone or Mineral Spirits, let dry, then paint it. The Rustoleum product you linked is fine.
A quick scuff will make for a better lasting job. A couple of light coats, dry time between them.
Offline jakec
« Reply #16 on: November 17, 2018, 11:54:38 AM »
Awesome, thanks for the info.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
« Reply #17 on: November 17, 2018, 02:40:44 PM »
For frames I’m a fan of POR15 with their chassis black top coat. Goes on self leveling, not too glossy, very, very tough.
AwesomeCB
« Reply #18 on: November 18, 2018, 04:23:38 AM »
Like many others here, I've used it for frame touch-ups and recommend it. Can be found at Home Depot in my area; I'd also try Ace Hardware if you have any of those nearby.
Offline jakec
« Reply #19 on: November 18, 2018, 02:33:25 PM »
I live on the top floor of an apartment building with no elevator.. I was thinking I could blast the frame with water in the shower... then I started thinking what if I brought some other parts up here to wash them.. and then assembled the bike in the living room  ::)
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #20 on: November 18, 2018, 03:06:51 PM »
Sure, why not? They are easier to roll downstairs with front brakes.
Offline tlbranth
« Reply #21 on: November 18, 2018, 03:30:41 PM »
I've built a lot of outdoor stuff and painted with Rustoleum. I was never too impressed. The metal always rusted even with proper prep. For any kind of black bike parts I want to just touch up or outdoor brackets I want to paint, I use Hammerite smooth gloss black. It's way tougher than Rustoleum. Dries quickly. I put on 4 or 5 coats ten minutes apart. Downside - while it DRIES quickly, it takes a few weeks to CURE so it's not tough 'til then.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
  • Gusto mo titi ko?
    • project
« Reply #22 on: November 18, 2018, 03:49:47 PM »
Rustoleum black was great for doing outlines when we spray painted murals in our youth. We filled in with krylon, and outlined with rustoleum. Nice crisp lines...
Offline johans
    • corporate leather
« Reply #23 on: November 20, 2018, 06:32:39 AM »
The Rustoleum professional is a different animal than the old school rustoleum we would buy as kids . Industrial grade paint ( i use a siphon cup and thin w/ acetone ) . Blends are VERY easy for any future damage.  Never had much long lasting luck w/ POR-15 . Always prepped the surface very well but it would flake in spots . Had over 20 Alfa's that are notorious for rusting , would try por-15, Bill Hirsch Miracle Paint  ( the Navy uses that also ! ) navel jelly ... ng-
1st 750k we used the Rustoleum w/ no primer and it is holding up great and the current 750F i primed it w/ a Rustoleum red primer and the semi-gloss black w/ also great results .  We degreased frames w/ Toluol and a light scuff for adhesion. Even used it for the tanks , final wet sanding w/ 800 , decals and a clear coat.
In a bathtub i would also use a enviro. friendly Simple Green ( not Toluol ) .
good luck -
1978 CB750K
1976 CB750F SS
1978 CB750F
1979 Honda 400T
1979 BMW R65
1979 Kawasaki KZ400
1988 Suzuki GSXF
Kawasaki 200 KDX
Yamaha YZ 250F
Offline jakec
« Reply #24 on: November 20, 2018, 09:13:01 AM »
If I don't have a spray gun, is it going to be alright to just use the rustoleum spray can? I will do all of the necessary prep to the frame .
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
