Author Topic: reusing conrod bolts  (Read 3174 times)
Offline topgun
« on: October 19, 2018, 12:59:29 AM »
Hi Guys I,m rebuilding a 750 with Mtc rods 900 pistons  etc what are your thoughts on using the same rod bolts I am getting conflicting opinions  on this subject I want to build this motor properly as I have invested a lot into it already as you will all appreciate Cheers Tony
Offline bear
  • Leeton in Australia
Re: reusing conrod bolts
« Reply #1 on: October 19, 2018, 02:43:05 AM »
New bolts, they should only stretch once.
Brian
« Last Edit: October 19, 2018, 02:52:21 AM by bear »
Offline simon#42
  • liverpool
« Reply #2 on: October 19, 2018, 09:51:34 AM »
yes new bolts .
Offline topgun
« Reply #3 on: October 19, 2018, 11:03:09 AM »
Thanks Guys
« Reply #4 on: October 19, 2018, 04:36:58 PM »
Are those answers geared to all rods , or aluminum in particular ?
Offline bear
« Reply #5 on: October 19, 2018, 05:16:18 PM »
As far as I'm concerned conrod bolts are a consumable, same as clutch plates, piston rings, cush rubbers and the like.
So.. in my opinion, my answer is geard to all rods.
This isn't going to turn into an "oil thread" is it Frank? ;D
« Reply #6 on: October 19, 2018, 11:33:34 PM »
Even Honda stock rods? I have a set of CB900 rods I might use if find a way to use the longer rods.
- These need new bolts and nuts?
Honda might have torqued them less than tuners do, like head nuts.
Offline simon#42
  • liverpool
« Reply #7 on: October 20, 2018, 04:28:50 AM »
i would always change them , there are places where you can save a bit of money and there are places where the consequences of a failed component far out weighs the price of a new one .
« Reply #8 on: October 20, 2018, 05:21:57 AM »
Carrillo told me years ago the 1/4" Carr bolts are good for an infinite number of "torque sequences".
I agree OEM rod bolts are consumables and it makes me nervous what Carrillo told me. They talked me out of it last time I asked, However I think I'll push the issue this time. I'm certain they'll gladly sell me new bolts!  ;D
« Reply #9 on: October 20, 2018, 08:01:39 AM »
Yes...the SPS bolt can be reused as long as they are not over torqued (overstretched). For what they cost they should be reusable.
Offline bear
« Reply #10 on: October 20, 2018, 08:06:59 AM »
I wouldn't use the M3 rods Peewee. Check to make sure you have the upgraded M4's.
Brian
« Reply #11 on: October 20, 2018, 10:45:33 AM »
Brian
M3 rods.... Is that CB900 dohc 79-82?
M4 later?
I heard the CB900 rods are a little bit stronger than CB750 stock.
CB750 Stock with new F2 bolts might be OK for 836-900cc anyway. Around 80whp
« Reply #12 on: October 20, 2018, 12:19:23 PM »
 How about Goldenrod bolts ?
« Reply #13 on: October 20, 2018, 08:40:14 PM »
Some used SPS bolts...I know that for a fact.
« Reply #14 on: October 21, 2018, 01:55:37 AM »
What is an SPS bolt and how do you identify it as being one?  ..no, I  didn't google it.
« Reply #15 on: October 21, 2018, 11:43:20 AM »
