Author Topic: CB650 forks on a CB550  (Read 2819 times)
Offline MotoRico
« on: January 17, 2007, 08:23:52 PM »
Will this work?  79 CB650 forks on a 74 CB550.
Offline scunny
  • don't call me expert
Re: CB650 forks on a CB550
« Reply #1 on: January 17, 2007, 09:09:11 PM »
if the tubes are the same diameter then yes, if not you will need the triple tree as well, as long as they fit.
 my00.02
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #2 on: January 18, 2007, 05:27:10 AM »
           Far as I know the 650 SOHC fork tubes are 35mm and that's the same as the 550s. Anytime you want to check out fork tube size, just go to ohiocaferacers.comand there is a link there, that will take you to a pretty complete list of different years of different bikes. Hope that helps.
                                                        Later on, Bill :) ;)
Member # 1969
Offline hahnda
  • lskdfhs;dljksa;
« Reply #3 on: January 18, 2007, 06:28:18 AM »
I'm pretty sure I have CB650 forks on my CB500. I didn't do the swap, it came that way in some attempt to make it look like a chopper or something. You might want to measure but I think the 650 forks might be a little longer. Are you trying to swap just the fork tubes or the wheel also? Also the triple?
Easiest swap is take the whole 550 front off including the triples and then just bolt in the 650 front end. It might be possible to not use the 650 triples and then just slide in the tubes into the 550 triples  if the fork spacing is the same on those 2 models. I think it is but would have to double check.
That list on ohiocaferacer is a decent one. I compiled it about 2 years ago.  ;D There are a few errors though that I really should have fixed. I also have a list of steering stem diameters that helps out when you want to do stem swaps.
Kevin
CB750K4 in pieces
CB750K3 with F trim
CB750K7
CB500 Cafe Project
CB750 Cafe
Offline Einyodeler
  • Midnight bugs taste best!!!
« Reply #4 on: January 18, 2007, 09:58:52 AM »
It depends on which model.the 650 Custom has dual front brakes so the spacing is wider and the steering stem is also slightly longer.
I`ll take some pics and post them tonight when I get home.
1972 CB500 - 1973 CB500 - 1974 CB550K - 1975 CB550F - 1975 CB750F - 1976 CJ360 - 1983 CR480 - 1970 BSA A65T Thunderbolt
Download Motorcycle Shop Manuals here: http://forums.sohc4.net/index.php?topic=17788.0
