Author Topic: Cb550 top end check  (Read 415 times)
Offline Sdsbassist
  • Gus, Austin, MN.
Cb550 top end check
« on: November 08, 2018, 08:02:25 PM »
Building a Franken bike. 77 and 78 parts.
Base had broken fins, so top end is off. Checked for piston play, seems good.
Do I need to do rings, etc. Using a new base with good fins so guessing will need to hone.
Sent from my SM-G920V using Tapatalk
Gus, Austin, MN.
Current Bike:  75 750F
Past bikes: 76 750K - "Iowa Blue",78 750K Craigslist find - "Black Beth;" 77 CB750K Basketcase, with a 75K engine; 1970 Cb750 K1, "Rosa Luxembourg"
74 cb750, 75 cb550, 77 kawa 650, 81 virago 750, 83 virago 920, 80 Honda Twinstar 200, 71 Honda CT70, 1971 Honda CB750 Rat Project "Black Dahlia Bitsa"
Offline Sdsbassist
  • Gus, Austin, MN.
Re: Cb550 top end check
« Reply #1 on: November 08, 2018, 08:02:55 PM »
Pics
Gus, Austin, MN.
« Reply #2 on: November 09, 2018, 01:17:37 AM »
What do you mean by base? If you mean cylinder block and you are going to hone it then yes you need new rings
