Author Topic: Offset front sprocket  (Read 794 times)
Offline frankie 2 sheds
« on: November 14, 2018, 03:21:45 AM »
Hi, I have a cb750 K. I intend to fit an 10mm offset front sprocket striaght onto the drive shaft so I can fit a wider wheel. Before I purchase the sprocket (not cheap) has anyone done it? There is very little room for a standard sprocket let alone an offset one. Will it fit on the drive shaft without having to strip the engine??? Thanks.......Frank
Re: Offset front sprocket
« Reply #1 on: November 14, 2018, 08:45:45 AM »
What year motor ?
 Use a 77 or 78 750 motor and sprocket will be 10 mm further out.
Offline tlbranth
« Reply #2 on: November 14, 2018, 08:17:05 PM »
Can't you lace the bigger wheel to the original hub?
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
