Author Topic: tourque values  (Read 1371 times)
Offline Mantree
tourque values
« on: November 24, 2018, 07:33:08 PM »
I am getting ready to change some engine cover gaskets and will be swapping out the screws for socket heads.  I have been told that tourque doesn't matter but it is a aluminium block and I would hate to strip a bolt hole.  Dose anyone have the tourque values for the engine bolts?
Sent from my SM-G930V using Tapatalk
Re: tourque values
« Reply #1 on: November 24, 2018, 11:35:50 PM »
What bike?
With only a few exceptions my policy is to use the original screws/bolts as much as possible as they offer the correct alloy to prevent erosion/electrolysis. Torque values are specified in the first few pages of the various Honda Shop Manuals that can be found here: http://forums.sohc4.net/index.php/topic,17788.0.html. I use my torque wrench only where really needed. For the rest I do it by feel and, by doing so, I preserve my skill.
« Last Edit: November 25, 2018, 06:36:22 AM by Deltarider »
Re: tourque values
« Reply #2 on: November 24, 2018, 11:46:48 PM »
Engine covers are fastened with M6. Max torque for the std grade screw is 12Nm which is too much for aluminium.
I have tightened my covers with 10Nm. Thread lenght is an important detail too. I prefer min 10mm. If only 5mm the torque can't be over 5Nm.
I have lately reduced to around 5Nm with a 1 hour later re-torque when gasket has compressed. It's too easy to strip the threads. No leaks.
Convert Nm -Ft lbs  https://www.convertunits.com/from/N+m/to/ft+lb
Offline Mantree
Re: tourque values
« Reply #3 on: November 25, 2018, 05:26:17 AM »
What bike?
With only a few exceptions my policy is to use the original screws/bolts as much as possible as they offer the correct alloy to prevent erosion/electrolisis. Torque values are specified in the first few pages of the various Honda Shop Manuals that can be found here: http://forums.sohc4.net/index.php/topic,17788.0.html. I use my torque wrench only where really needed. For the rest I use my skill and, by doing so, preserve it.
It is a 75 cb750k and there are 2 bolts that haven't been destroyed by somebody who was in the engine before me.
Offline Mantree
Re: tourque values
« Reply #4 on: November 25, 2018, 05:27:46 AM »
Thanks I guess I will calibrate my tourqu wrench after work today (it's been about a year since it was last used) and my next day off I'll start wrenching.
Re: tourque values
« Reply #5 on: November 25, 2018, 05:55:27 AM »
 For the engine covers and valve cover bolts etc. you should be fine if you just go by 'feel' and not going at it with a big torque wrench.  You can go back and re-check after the gasket has settled in. Use some anti-seize if your using stainless fasteners.
Online seanbarney41
Re: tourque values
« Reply #6 on: November 25, 2018, 06:05:29 AM »
Do you have a 1/4" drive torque wrench?  If no, don't try it with a big one.
Re: tourque values
« Reply #7 on: November 25, 2018, 06:37:07 AM »
I use a small torque wrench for these small things, 2.5-25Nm. 1/4” sockets. It cannot be a long one.
I have another for the head, clutch etc. 10-60Nm.
Cam towers need the small that will not tight too much.
Offline 540nova
Re: tourque values
« Reply #8 on: November 25, 2018, 08:52:09 AM »
If you use any kind of lubricant,  whether it's oil, anti-seize, or whatever,  throw the listed torque specs out the window.  Torque specs are for dry fasteners,  which is a bad idea,  especially if using stainless steel bolts and screws.
Sent from my SM-G955U using Tapatalk
Re: tourque values
« Reply #9 on: November 25, 2018, 09:45:23 AM »
I've read this often and I wonder what the theory is behind this.
Online bryanj
Re: tourque values
« Reply #10 on: November 25, 2018, 10:28:59 AM »
Galvanitic, electrolitic or whatever itic you care causes corrosion between different metals and stainless is worse than BZP.
The difference between wet and dry torque is well documented.
Re: tourque values
« Reply #11 on: November 25, 2018, 11:23:34 AM »
I use lightly oiled cyl studs and oil under nuts when tighten head. All other dry.
Cam bolts with blue loctite and tighten it hard with a 10mm  wrench. That small tool will reduce the power.
Re: tourque values
« Reply #12 on: November 25, 2018, 01:03:45 PM »
Excuse my ignorance, Bryan, but what does 'itic' mean and what is 'BZP'?
Ah..., I hope can find it.
I use ... oil under nuts when tighten head.
I remember that Honda The Netherlands advised this practice after being confronted with mounting complaints concerning CB500s sweating oil near the headgasket. That's why I asked what the theory is behind this, because it seems to contradict what 540nova stated or?... I'd like to learn more on this.
« Last Edit: November 25, 2018, 01:55:15 PM by Deltarider »
Online bryanj
Re: tourque values
« Reply #13 on: November 25, 2018, 03:55:53 PM »
Bright Zinc Plated and the galvanitic is very basicaly a battery where one metal corrodes passing electrons to the other.
Offline Mantree
Re: tourque values
« Reply #14 on: November 25, 2018, 08:17:08 PM »
So what I am getting is anti-seize and hand tight with a short ratchet
Offline awrawr
Re: tourque values
« Reply #15 on: November 26, 2018, 12:30:02 AM »
Be careful. A long time ago I had several stock bolts on rocker cover of my 400/4 shear whilst undoing them. The galvanic corrosion had virtually welded them in place. I learned how to use helicoil inserts pdq. But on a couple of the holes the damage i did extracting the remains meant going up to m8 which wasn't ideal. (I was clumsier then and didnt have many of the right tools.)
Re: tourque values
« Reply #16 on: November 26, 2018, 07:27:11 AM »
It's dead easy: just stop right before it snaps.  ;D
« Last Edit: November 26, 2018, 08:15:43 AM by Deltarider »
Online bryanj
Re: tourque values
« Reply #17 on: November 26, 2018, 07:54:50 AM »
Decades ago as a marine engineer i asked the 2nd how tight he wanted the 3/8 nuts and bolts i was doing up. He said "till they snap and back half a turn"--------he was really pissed when that is what i did.
