Author Topic: Turbo Billet Block CB750 Racer  (Read 3218 times)
Offline Cb750 Racer
« on: November 30, 2018, 03:28:48 PM »
Before I begin I want to give a huge shout out to Kenny over at Cycle X and the one and only Mrieck here on the forum for all the help and guidance they've given me. I think Ilja's cb750 and Bill's Purple rain builds deserve their mentions as well for planting the seed in my head for a boosted build. Also a big thanks to Bill Benton, 754, Medyo Bastos, and eli for sourcing countless parts for the build you all have been a huge help in making this possible.
The engine aspect of the build can be found in the high performance section under "Turbo Billet Block CB750" I figured it was best to start a new thread entirely in this section of the forum for the chassis aspect of the build. I had previously made a thread about the build but it was too wordy so I hope this thread can be more easily digested. This bike was a genuine racer back in its day but was crashed and left to rot in a back yard before I found it. Previous RC 850cc engine was destroyed when crashed in the early 80's.
The Frame of this bike is a K1 so all the supersport parts were modified to fit.
There are little to no photos of the bike 3 years ago when I first got it but many of the vintage race parts that are on the bike now were on the bike then such as:
-Dresda swingarm
-Krober tachometer
-Wheel set (Goldwing front hub and 750f rear hub both laced to DID aluminum rims)
-Brake set (750f rear and cast iron twin disk up front)
-Futura headlight mounts now flipped upside down to look modern
-Home made aluminum rearsets
-Worked fork set by Forking by Frank
-Vintage aftermarket twin front brakes and rear sproket
-That #$%*in seat (Brand unknown)
All the parts you see have been thoroughly cleaned and rebuilt this past year but overall the chassis work has been a bit neglected. Since the engines been on hold at Mikes shop the chassis has been the only thing I've been working on.
I have a new supersport tank on the way as this one was on it's last leg the last time I redid it so I guess my brother knocking the bike off my lift was a gift and a curse. An aftermarket petcock and modified tank breather are going to be addressed the moment the new tank arrives. Again shout out to Medyo Bastos here on the forum for always hooking it up when I'm in need.
The bike had no side covers when I first picked it up so I didn't know how bad it would look with standard F1 covers on it. I decided to cut the rear of the cover to match the lines of the frame. I plan to get a cover for the oil tank and do the same thing as much as I hate covering the AAMRR sticker
The seat doesn't currently sit flat on the frame as the sides of the seat hit on the rear shocks. I'm going to make a custom wood insert under the seat just to raise it 1/4 inch an make everything sit flush. The seat will also be cut in the front to match the angle of the tank so it sits flush in that regard too.
Finding a place for the rear taillight that also fits the theme of the bike has been a challenge for sure i'm gonna attempt to mount an LED strip under the seat which will look sleek and badass at night.
All new brake pads and stainless brake lines are in the near future as well. I'm going to ditch the original brake light switch and run both the lines from the calipers right to the master cylinder for maximum response. the master cylinders and calipers will all be rebuilt and polished to fit the scheme of the bike as well.
The steering damper was made out of two I had laying around. I couldn't find one that would work right for under 300$ so I had to improvise and I think it came out alright.
A very large oil cooler is going to see itself onto the bike . Whats the biggest unit ever fit on one of these frames? I've been looking at some 11 x 7 x 2 inch coolers utilizing 8AN lines but I don't want it too look too preposterous.  The battery area will be sectioned off with sheet metal so the heat from the turbo doesn't see itself into that area. I'm thinking a Water-Meth tank will sit where the old electronics used to sit, hopefully a 1 gallon tank? Once I finish up with some more mods everything that looks less than perfect will be powder coated. I'm thinking of leaving the seat with the original paint but may have it redone exactly the way it is.
« Last Edit: November 30, 2018, 09:24:05 PM by Cb750 Racer »
Turbo Billet Block cb750
1975 Honda CB400f
1972 Suzuki GT750J
1984 Kawasaki GPZ900 Mr.Turbo Top Gun build
2002 Suzuki Bandit 1200 Turbo
1979 Honda CBX
1990 Mr.Turbo Kawasaki ZX11
And Dozens More...
Re: Turbo Billet Block CB750 Racer
« Reply #1 on: November 30, 2018, 06:40:35 PM »
Following...really cool batch of old parts.  Have you serviced that ultra rare swingarm yet?  It may need new bearings, as the Dresda's use tapered roller bearings.  I have Timken numbers required, if so.
KIMG0099 by Sean Barney, on Flickr
KIMG0098 by Sean Barney, on Flickr
KIMG0224 by Sean Barney, on Flickr
« Last Edit: November 30, 2018, 07:04:38 PM by seanbarney41 »
« Reply #2 on: November 30, 2018, 07:10:40 PM »
Also, those do not look like GL1000 rims to me...gl rims do not have the dropped center.  Very nice anyway though.  Is the rear a 17"?
Offline Cb750 Racer
« Reply #3 on: November 30, 2018, 08:43:34 PM »
Funny you mention it I just went through the swingarm the other week. Roller bearings were in really good condition just needed a proper cleaning and some grease. The wheel set could from a Goldwing and truthfully I wouldn't be surprised if that was the case. I checked the rear rim it's labeled 18x3 front is 18x2.5.
1975 Honda CB400f
1972 Suzuki GT750J
1979 Honda CBX
And Dozens More...
« Reply #4 on: December 01, 2018, 06:05:40 AM »
Gold wing rims are 19f 17r, I don't know the widths right off hand, also stamped d.i.d., and possibly a d.i.d. sticker
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #5 on: December 01, 2018, 08:08:41 AM »
Do you want me to check under my bed for a gw wheel?
Offline Ilja
« Reply #6 on: December 01, 2018, 09:05:16 AM »
Notifications - ON. :)
Offline Cb750 Racer
« Reply #7 on: December 01, 2018, 01:25:32 PM »
They are both stamped and have stickers. I thought it was a custom wheel-set but I think that confirms it. The spokes just seemed way to thick to come on a production bike they're almost in Harley straight spoke territory  ;)
I appreciate the quick response I definitely learned something new today.
Medyo do you hold any records for largest bed in America ?  ;D I think it's best to rebuild the set on the bike, changing rim sizes would definitely throw off the stance of the bike. Plus I hate to see this fresh set of tires go to waste. Thank you for looking out for me though I can't wait until that tank comes in the mail!
I wish there was a way to turn them on  ::)  I'm always missing replies sorry to anyone I've left hanging before
1975 Honda CB400f
1972 Suzuki GT750J
1979 Honda CBX
And Dozens More...
« Reply #8 on: December 01, 2018, 11:58:23 PM »
You can modify last or any of the posts you have done, click  "Attachments and other options", check  "Notify me of replies."
Offline Cb750 Racer
« Reply #9 on: December 06, 2018, 02:22:59 PM »
PeWe that's amazing no more people left hanging for weeks on end haha, again sorry if I have forgot to respond.
The new tank looks surprisingly good with the seat. Just ordered some of those small suction cup dent pullers hopefully I can work these dents out a bit. The dents are somewhat shallow so I think it's do-able. Regardless this is a far better base than the tank I had on the bike before now I just have to modify this one so the rear sits a little lower and matches the lines of the seat.
1975 Honda CB400f
1972 Suzuki GT750J
1979 Honda CBX
And Dozens More...
« Reply #10 on: December 07, 2018, 10:39:23 AM »
This is also useful on interesting threads you want to follow.
« Reply #11 on: December 07, 2018, 06:14:26 PM »
Here is the bed Medyo  uses to guard his parts..
