Your post said: “knock out the guides and replace the seals.... as it’s something I routinely do”. You make no mention of recurring seats, and as I said, replacing seals does not necessitate guide removal.
If a guide is worn, replace it (as I said). If it’s not worn, replacing it is superfluous and costly. The OP had a cracked guide if I recall now, certainly cause to replace that one (and any other in need). But replacement for the sake of replacement is foolish and zero benefit.
