Author Topic: Wheel off center?  (Read 851 times)
Offline kerryb
  • Not a very
Wheel off center?
« on: December 15, 2018, 10:40:23 AM »
Is it normal for the rear wheel of a cb650 to be off center by a little bit?  The chain runs true on the sprockets, but the wheel is off-center on the swingarm (about 3/16") and offcenter in the top frame rails of the seat area ( about 1/2").  Is this common?
Offline DaveBarbier
Re: Wheel off center?
« Reply #1 on: December 15, 2018, 04:17:34 PM »
Can you run string from the rear to the front and see if they are aligned? I don’t believe they are intentionally off center. What year 650? Is this spoked or mag wheels?
« Reply #2 on: December 15, 2018, 11:54:30 PM »
Spacers misplaced or wrong type used?
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=19ei6cmoedaiq97mm88dljmjk2&/topic,60973.0.html
« Reply #3 on: December 16, 2018, 02:41:59 AM »
the sving arm often bends..its soft(vhy it bend) and can easy be korrekted..easyest to see,if you take a straight piece of vood and hold against the parallel tubes..and have a look from back...
i hate all this v-w.... vords
Offline kerryb
  • Not a very
« Reply #4 on: December 16, 2018, 06:42:00 AM »
'82 cb650sc,  comstar wheels, which I've had off recently and didn't reinstall properly before trying to measure at the limits of swingarm travel.  My bad...sorry to waste your time!  But thanks for trying to staighten me out. ;D
