Good news: after removing the cam, I was able to grab the threads with needle nose pliers and unscrew the bolt.
After that, I reinstalled the cam, then used non-hardening gasket material to seal the pucks in place (following along in Hondaman’s book. I cleaned it all up and put the valve cover back on and hand tightened all the bolts
Tappet adjusted to spec and the engine is back together. I noticed my timing mark (T - F) for 1-4 is slightly off TDC (5-10 degrees).
I set the cam timing based on piston 1-4 TDC, not the timing plate as I noticed it was off at that point. From what I remember, I can bend springs to adjust the timing plate to the proper location.
Exhaust headers (MotoGPwerks courtesy of Cal) with SS spigots were installed.
Next step is to finish cleaning carburetors to be spotless, then put them back on. With the JMR Stage 2.5 head work, CB650 cam, the MotoGPWerks exhaust, port matched intake runners and TinTop Anti-pod filter, I think this engine should breathe nicely.
Living at sea level, I think I’ll start jetting at 1 size up from Stock specs. My beginning thoughts are #40 Slow Jet, Lift needle +1 notch, #105 Main.
Any other thoughts/recommendations?
