Author Topic: Looking for Airbox Assembly for 78 cb550k  (Read 4292 times)
Offline mkmob
« on: January 02, 2019, 01:58:14 PM »
Hi folks,
This is my first post on these forums. I recently purchased a 1978 cb550k and i'm in the process of restoring it. This is also my first bike and I'm completely new to the art of motorcycle repair/maintenance. But it's something I've wanted to do pretty much my whole life and I've already learned a lot.
Anyway, to the point... The person I bought the bike from replaced the original airbox assembly with pod filters and either sold or lost it. So now I'm trying to track down a replacement and I'm having some trouble finding one. I know that the 77 and 78 550's have different carbs than the other 4's and so I've been searching online for the assemblies from those. There's very few original airboxes online for any of the 550's and I have yet to find one for either a 77 or 78.
Anyone have any suggestions on where I might be able to find one of these?
Thanks!
'78 cb550k
"Sometimes it's a little better to travel than to arrive"
Re: Looking for Airbox Assembly for 78 cb550k
« Reply #1 on: January 02, 2019, 02:52:19 PM »
Welcome.  Use a site like CMSNL.com and their parts fiche to locate the part(s) number(s).
In your case, you'll need most of the parts listed.   ;D
https://www.cmsnl.com/honda-cb550k-1978-usa_model7222/partslist/F++16.html#.XC1AatTwYdV
« Reply #3 on: January 02, 2019, 03:03:34 PM »
That is the hardest part to find, or rather the rubbers between box and carbs are.
Offline Scott S
« Reply #4 on: January 02, 2019, 04:16:37 PM »
 The air box itself is the same on all 550's. The rubber intake boots are different for '77-78 and new replacements are available.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline AlekStooge
  • can't afford cheap stuff
« Reply #5 on: January 02, 2019, 04:57:13 PM »
I have a 1978 air box that I won't be using.
« Reply #6 on: January 03, 2019, 04:42:23 AM »
Scott, i regularly see the rubbers for the 500/550 with none PD carbs but i cannot find any for the 77/78K WITH PD carbs as they are different. Airbox is a different part number as well.
Offline Scott S
« Reply #7 on: January 03, 2019, 05:45:27 AM »
 For the rubbers, email Paul at Classic Motorcycle Solutions.
  mybluebike2004@yahoo.com
 The plenum for the air box is the same. It just uses different intake rubbers. The air filter section only changed as far as EPA stuff; where breather hoses went, crankcase recovery system,  etc. Any 500/550 air box will work if you're not concerned about the exact vapor recovery system for your particular year.
'71 CB500 K0
'81 Yamaha XS650
Offline Deltarider
« Reply #8 on: January 03, 2019, 07:38:12 AM »
The CB550K3/4 had somewhat longer intake runners as these models were marketed for cruising and less for sportive riding.
CB500K2-ED Excel black
Offline Scott S
« Reply #9 on: January 03, 2019, 08:00:39 AM »
 They used shorter rubbers on the intake manifolds and longer rubbers on the plenum, to fit the PD series carbs and use the same manifolds and air box parts.
'71 CB500 K0
'81 Yamaha XS650
« Reply #10 on: January 03, 2019, 12:11:57 PM »
+1
...Except the intake manifolds were different than the early models with elimination of the vacuum test ports, as the PD carbs have them incorporated into the carb bodies.
The rubber bits were different because of mechanical size fitment of the PD carbs.  Absolutely nothing to do with the Delta's fictional storytelling.
Offline mkmob
« Reply #11 on: January 03, 2019, 05:45:31 PM »
Wow, I didn't expect this many replies so quickly! Thanks everyone for all the helpful information! I was starting to feel a little discouraged but I think I'm now pointed in the right direction.
Good to know that the air boxes are essentially the same aside from the boots. I'm now wondering if the the previous owner attempted to rejet the carbs when they installed the pod filters. Although it seems from what I read, retuning it with the original air box should be relatively straightforward.
Anyway, I'm glad to see that this community is still so active and helpful. Hopefully I'll be able to pay it forward once I get some more experience under my belt.
'78 cb550k
Offline Deltarider
« Reply #12 on: January 04, 2019, 04:02:49 AM »
In reply #8 I passed on the info briefed by Honda back then. These models were marketed in continental Europe as cruisers opposed to the somewhat sportier F models. Honda also explained that that's why the K3 had a rear sprocket of 34 teeth fitted and not the 37 teeth sprocket the sportier F models had. If that's fictional storytelling, at least I did it in conjuction with Honda.
Offline 05c50
  • 05c50
    • Classic Motorcycle Solution
« Reply #13 on: January 04, 2019, 05:48:52 AM »
"still active" haha, it's a full time job trying to keep up with all the daily posts. :)
.........Paul
« Reply #14 on: January 04, 2019, 05:52:28 AM »
I have one, less the rubber boots in 4 sale.  In the last 2 or 3 weeks.
 Take a look, I be back on here in a few hours.
Offline trigger
  • Engines built on reputation, not advertising.
« Reply #15 on: January 04, 2019, 06:01:22 AM »
These are the ones for the PD carbs Bryan >>> https://www.ebay.co.uk/itm/77-78-HONDA-CB550K-K3-CARB-INTAKE-SET-INSULATOR-4-INTAKES-INCLUDE-CI-CB550K3INBT/251544929658?hash=item3a913f057a:g:xVYAAOxyF0pTiW5r:rk:3:pf:0
« Reply #16 on: January 04, 2019, 09:01:57 AM »
My K3 had/has a 37 tooth rear sprocket  In fact, all my CB550 do, along with the same size front sprocket.  Please show the part number difference between the F model and the K model to back up your story.
The CB500s here in the US had 34 tooth rear sprockets.  They also had different primary chain gearing to offset the final ratio gearing.
Offline Deltarider
« Reply #17 on: January 04, 2019, 10:12:21 AM »
It's on p.62 of the appropiate Parts List which you can study here: http://www.honda4fun.com/pdf_parts_list/pdf_spac500-550/CB500-550_K3-K4.pdf At your service.
Offline Tracksnblades1
« Reply #18 on: January 04, 2019, 10:35:06 AM »
Good info, possibly can clear up any little anecdotals.
Thanks for the Part numbers Delta, sometime them pesty specifics can be hard to produce.
Good Health and a prosperous 2019
Age Quod Agis
« Reply #19 on: January 04, 2019, 10:47:32 AM »
All of which has nothing to do with intake runner/rubber differences.  But something to do with euro and US marketing differences.
Or, are you now saying the intake rubbers are different for US and euro markets, too?
Offline Deltarider
« Reply #20 on: January 04, 2019, 11:23:00 AM »
I've been quite specific in reply #12, sir. Now, this may have been spinned by Honda but that's how it was brought by them when the K3 was released to the German market. Please see my reply #8 where I specifically used the word 'marketed'.
Offline b1jackson
« Reply #21 on: March 26, 2019, 10:24:33 AM »
Exactly what I was looking for.  My boots are cracked and crusty!
« Reply #22 on: March 26, 2019, 11:52:31 AM »
The person who posted the ebay link, those are carb to head rubbers that all Honda dealers can get if they wish to try and help. Its the plenum to carb rubbers that only exist when made by a member on here.
Offline Tom in Newcastle......Ontario
  • Newcastle Ontario
1978 cb 550k......stock,my first re-build
Loud pipes suck.......
If you buy something.........pay for it !
If you sell something .......ship it !
If you say you are going to do something......do it !
If you have a question about something......ask it !
When the seller answers ........let him know whether you still want it or not !
If you receive something .....let the seller know you got it !
If you get something and are happy/un happy with it .....let the giver/seller know !
If you have any kind of issue,shipping/receiving/quality/price/shipping charges etc !
Communicate
Offline Scott S
« Reply #24 on: March 26, 2019, 04:51:35 PM »
 I haven't bought any in a while but the ones Paul sells are (were) WAY less expensive.
'71 CB500 K0
'81 Yamaha XS650
