Author Topic: Radical Gas Tank Cleaning Option  (Read 7904 times)
scout18
Re: Radical Gas Tank Cleaning Option
« Reply #25 on: January 11, 2007, 09:32:00 PM »
Hey I like the electrolysis idea. I have cleaned old tools this way.  my only question for you is, why is the tank all wrapped up?javascript:void(0);
Huh
Offline Pinhead
  • 1979 CB652-ST
« Reply #26 on: January 11, 2007, 11:06:32 PM »
Did anyone else get a really pretty picture when clicking the above link?
http://twostrokes.com/Tech/html/electrolysis.html
Doug
GM HEI Ignition Conversion
Quote from: TwoTired
:D
Offline puppytrax
« Reply #27 on: January 12, 2007, 03:28:07 AM »
I got a "404 Error - Big Honkin' Oops" message, but no pic...   ::)
...stock 1972 CB500 '500 Four' undergoing re-assembly...
...Stock 1972 CL450 'Scrambler' also being re-assembled...
Offline xtalon
« Reply #28 on: January 12, 2007, 06:43:52 AM »
Hang on and I'll let you know.... trying to type w/ one hand.   ;D
1976 Honda CB750K
2006 Yamaha R6v
scout18
« Reply #29 on: January 20, 2007, 06:27:55 PM »
Ok I tried the electrolysis with baking soda and it works fine Iam rally pleased with this method as it invloves no hazardous chemicals. as far as cleanign the rust? WOW nice and shiny inside.
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #30 on: January 20, 2007, 11:54:16 PM »
jerod--did you just clean a tank out? i've been thinking about making an electrolysis tank out of a 35G plastic garbage can, with some sheet metal wrapped around the inner circumference as the anode, but everything i've read seems to indicate that the power supply is critical to how well (or delicately) it works. i'd love to see your setup.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Texwing
« Reply #31 on: January 21, 2007, 06:05:55 PM »
I am ready to try this, how much baking soda did you use per gallon of water?
Texwing
Re: Radical Gas Tank Cleaning Option-I'm doing this, no explosions yet!
« Reply #32 on: January 22, 2007, 02:32:46 PM »
OK, I just jumped in and am about 5 hours into this-here is the report:
1. Baking Soda, cheap and easy to find, seems to work, dont know how much to use, went with about a tablespoon a gallon.
2. I  dont know if the baking soda gives itself up during the process, and thus whether the amount is important.
3. The reason an earlier post so completely wrapped his tank is ... I dont know, but I had an issue with the condensation of the process collecting into the spray paint cap/anode covering the gas cap hole and then weeping back down onto the tank, it was dripping pretty good, did not seem to damage the old paint but you would not want to take a chance.
4. I solved the weeping wet tank issue above by adding a vent line from the anode holder to a small vacuum source (old aquarium pump using the vacuum side, no more weeping.
5. After four hours i drained and looked-Lost of rust had vanished, much remained, the anode was ugly, and a nasty rust/crap froth was collecting at the gas filler hole, so leave yourself 1/2 inch or so for this muck to stay in the tank.  The rust that remained that i could get too was loose and seemed to be dissolving, for some reason i thought 4 hours would do it, but i read the earlier post and its maybe two days...good thats its february.
6. i have restarted the process and used alot more baking soda.
7. Amperage dropped fro 4 to 2 amps quickly, I noted about a 20 degree f rise over ambient during the process.  Might be nice to know since temperature is easy to monitor whether the end of the process can be determined by  an increase or decrease of temperture or amperage...
