Author Topic: CB550K1 - swingarm bushings plastic -> bronze clarification  (Read 729 times)
Offline Erny
« on: February 02, 2019, 03:52:18 PM »
I'm preparing for worn bushings replacement.
For the replacement I underarstand those from twowheelsfrank are recommended https://www.ebay.com/itm/Honda-CB-500-550-750-Four-Schwingenlager-Bronzebuchsen-Swingarm-Bushings-Bearing/132265500481?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
looking on partzilla, seems original ones are w/o flange/collar. But those bronze ones are with.
Should I understand that going for bronze ones I will replace honda stock, positions 11, 16 and 12? (see attached partslist)
CB750K K7 USA model (1977)
CB550K1 USA model (1975)
Re: CB550K1 - swingarm bushings plastic -> bronze clarification
« Reply #1 on: February 02, 2019, 04:09:09 PM »
Yup, but the bushes are worn a will bet the collar is as well (part 14) and that is pricey
Offline Erny
« Reply #2 on: February 02, 2019, 04:15:16 PM »
So, I should search for collar too, right? :(
Is there any other good alternative? Non OEM.
Offline Scott S
« Reply #3 on: February 02, 2019, 05:36:52 PM »
 You'll probably be just fine with the new brass bushings.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
« Reply #4 on: February 02, 2019, 07:26:08 PM »
Make sure the clearance between the bushings and the collar is NO MORE than 0.0012". Most aftermarket bronze bushings I have to (re)pull out of these arms are much looser than that.
