Author Topic: reinstalling engine  (Read 765 times)
Offline evinrude7
  • not a kung-fu
  • something to hüsker
reinstalling engine
« on: February 07, 2019, 04:53:56 AM »
it's back in the frame with all of the bolts in finger tight.  should i support it with a jack to where it's not putting pressure on the bolts and tighten them down or let it hang and tighten?  does it matter?
cb750 k6 - ugly
Re: reinstalling engine
« Reply #1 on: February 07, 2019, 05:18:43 AM »
I always let it hang and tighten.
Did you install swingarm already?  The rear bottom bolt has some say about the swingarm bolt, you want swingarm in before you crank it all down.
Offline Tracksnblades1
« Reply #2 on: February 07, 2019, 05:23:12 AM »
E7,
Sounds like you worry about some of the same things I find myself worrying about.
« Last Edit: February 07, 2019, 05:25:46 AM by Tracksnblades1 »
Age Quod Agis
« Reply #3 on: February 07, 2019, 06:14:57 AM »
also be sure the brake pedal spline/actuator/bell crank thingies and return spring is installed before swingarm
Offline rotortiller
« Reply #4 on: February 07, 2019, 06:19:50 AM »
Maybe you should load the engine CW in the direction of output torque! LOL
« Reply #5 on: February 07, 2019, 07:48:23 AM »
+1...I've made that mistake before!
« Reply #6 on: February 07, 2019, 09:08:56 AM »
  Its possible to fix it with the swingarm still on but the shocks have to be removed and it folded all the way up as far as possible to barely clear. Don't ask me how I know   ;D
