Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
it's back in the frame with all of the bolts in finger tight. should i support it with a jack to where it's not putting pressure on the bolts and tighten them down or let it hang and tighten? does it matter?
I always let it hang and tighten.Did you install swingarm already? The rear bottom bolt has some say about the swingarm bolt, you want swingarm in before you crank it all down.
Quote from: 70CB750 on February 07, 2019, 05:18:43 AMI always let it hang and tighten.Did you install swingarm already? The rear bottom bolt has some say about the swingarm bolt, you want swingarm in before you crank it all down.also be sure the brake pedal spline/actuator/bell crank thingies and return spring is installed before swingarm
Quote from: seanbarney41 on February 07, 2019, 06:14:57 AMQuote from: 70CB750 on February 07, 2019, 05:18:43 AMI always let it hang and tighten.Did you install swingarm already? The rear bottom bolt has some say about the swingarm bolt, you want swingarm in before you crank it all down.also be sure the brake pedal spline/actuator/bell crank thingies and return spring is installed before swingarm+1...I've made that mistake before!
