Author Topic: Interchangable headers.  (Read 670 times)
Offline KilledByGreg
« on: February 07, 2019, 07:13:26 PM »
Anyone know if you can use CB750F2 headers on a 750 K1?
Re: Interchangable headers.
« Reply #1 on: February 07, 2019, 11:53:00 PM »
If you remove the K1 stub pipes probably but as the F2 has different footrests they might hit things.
« Reply #2 on: February 08, 2019, 01:05:55 AM »
Yeah, what Bryan said. I did the opposite, I installed an F engine into a K2 so had to remove the F's exhaust studs and install the earlier exhaust stubs and 8mm screws from a K2, but it worked fine. If you're only using the F2 header pipe you shouldn't have any problems as the engines are all basically the same, as is the position of the centre stand on an F2 compared to a K1. ;D
