testy
Author Topic: Crankcase bearing replacement  (Read 172 times)
Offline macvit7906
« on: February 08, 2019, 08:50:01 am »
For anyone overhauling a 75 or 76 F0/F1,
Found this great article that lists out all the bearings you need and how to replace each one: https://wrenchandspanner.wordpress.com/2014/12/16/cb750f-transmission-bearings/
Very helpful.
« Last Edit: February 08, 2019, 10:41:17 am by macvit7906 »
Offline jamesw
Re: Crankcase bearing replacement
« Reply #1 on: February 08, 2019, 09:08:52 am »
I'm doing this for my F0 build.
Luckily I have a friend who works for a bearing company because honda charges quite a bit for some of those bearings.
72K-F 750 Cafe
75K 750 Cafe
75F 750 Restoration
Offline macvit7906
« Reply #2 on: February 08, 2019, 09:34:47 am »
Sounds like a nice hookup. I'll be paying full price over here. Though they are not too bad at around $50 for the most expensive bearing.
« Reply #3 on: February 08, 2019, 11:38:28 pm »
Yamiya sell most of the bearings. Some of them with a groove. Needle bearings in primary hub use a standard needle bearing found on eBay if searching the size.
CB750 K6-76 1005cc JMR Billet block.
CB750 K2-75 Parts assembled to stock K2
Offline macvit7906
« Reply #4 on: February 09, 2019, 08:24:44 am »
Ended up using https://www.cmsnl.com for all bearings, new chains, new tensioners, etc.
Decent prices but great selection of OEM stuff.
Offline MessnerMoto
« Reply #5 on: February 09, 2019, 01:17:54 pm »
buy bearing anywhere from internet or local hardware store. Just look for SKF, KOYO, NTN... or other high quality bearings
take to machine shop to cut you grooves
10 times cheaper 10 times better
