You'll need better rods too.
One very important detail to be aware of is that 915cc means 68mm bore and fatter sleeves. CycleX sell their "915cc" kit that has 67.5mm bores/pistons which are not 915cc, its . Sleeves are tapered to avoid case machining.
Maybe just a little with dremel. My K2 case did not need it but my K6 did.
Calculate displacement:
((piston diam mm/2) x (piston diam mm/2) x Pi(3.1415926) x stroke mm)/1000
this multiplied with number of cylinders x4
Bore 67.5, stroke 63 mm gives 901.77 cc
When ordering rings or the entire kit its a good idea to mention the bore just for sure. The kit CycleX sells as 915cc has 67.5mm pistons
Dynoman however sell a 67.5mm kit they call 906cc.
CycleX has a good price on their 67.5mm kit. But it is no next step. Sleeves need to be replaced when scratched or worn out.
They have a 890 kit (67mm) which can be redone using their 67.5mm pistons in the future. But, the CR is higher 12.5:1 so the head might need some adaptation for street use and street gas
http://www.cyclexchange.net/Engine%20Parts%20Pistons%20Page/890cc/890cc%20Pistons.htm Dynoman has also 67mm kit (888,46cc) and tapered sleeves. 10.5 or 12.5:1 (I have Dynoman DP1000/71r kit, JE pistons (71.25mm)
One very important thing is your head you intend to use. Are the chambers widened or only the normal port job, the bumbs around the valves grinded off?
If head has open chambers, you'll need higher CR pistons than 10.25/10.5:1
Maybe 12.5:1 can fit then or special order from Dynoman that can adapt the pistons to actual chamber volume. I did that for my head that has 24.4cc. The "normal" volume the big bore kits Cormpression Ratio (CR) are calculated for is around 22.5cc for K heads.
F2 heads need higher domes.
I should check with forum member MRieck that can make the entire package to get a good working solution at once. Easier when one shop can order all correct stuff needed, do the machining/assembling and only one shipment. Maybe you need parts from all CycleX, Dynoman and APE. APE has their own rods as an alternative to Carillo, less $
