Author Topic: Time to go racing.  (Read 11902 times)
Offline Rocketman
Re: Time to go racing.
« Reply #25 on: June 22, 2021, 05:17:30 AM »
Enjoying your build.  Racing a 550 myself with AHRMA.
Some posts you may enjoy:
http://forums.sohc4.net/index.php/topic,83871.0.html
http://forums.sohc4.net/index.php/topic,149408.0.html
Offline Shtonecb500
    • Youtube profile
« Reply #26 on: June 22, 2021, 06:28:57 AM »
you've got some really nice stuff over there.
Offline Daggless888
« Reply #27 on: June 22, 2021, 11:38:08 PM »
Cheers Rocketman. I have been following your build for a while and enjoying your journey back into racing. Thank you for the links.
Offline Daggless888
« Reply #28 on: June 23, 2021, 01:13:27 AM »
Thanks. I have been planning this bike for the last 3 years so started buying all the bits a while back so I don’t have to sit and wait for everything to turn up.
Offline Daggless888
« Reply #29 on: June 24, 2021, 01:05:12 AM »
As part of the planning process I used excel to log all the parts being used for this build. I wanted a comprehensive list of every nut and bolt used along with supplier details. I might have got a bit carried away but I had a lot of time whilst waiting for all the bits to arrive. I pinched the CSMNL schematics which are brilliant for all the detail. A bit nerdish but a great resource in the future when I get even older and more forgetful where the bits go and where I got them from. Some days I wish I could defrag the brain as it’s fills up with so much crap from everyday life….
Offline Daggless888
« Reply #30 on: June 24, 2021, 01:11:16 AM »
Wheels are trued and ready for tires. Used E2 bearings in the hubs which are low friction. I can spin the wheels, walk away and make a cuppa and by time I get back that are still going :-). I like that
Offline Daggless888
« Reply #31 on: June 26, 2021, 03:55:04 PM »
Avon am22’s fitted along with ap racing brake caliper. Had to remove a couple of mm from the back of the caliper. Used a belt sander as it was just touching the spokes. Good clearance now.
Offline Daggless888
« Reply #32 on: June 26, 2021, 03:58:36 PM »
Practicing safety wiring while I am going along.
« Reply #33 on: June 28, 2021, 08:34:16 AM »
Now the modified hubs make perfect sense.  Nice looking rotor.
Offline Daggless888
« Reply #34 on: July 02, 2021, 12:21:56 AM »
Rotor is a Davies unit. Really well made. Like the rest of their gear. Works really nicely with the ap racing caliper. Really happy with the hubs. They came out nice.
Offline Daggless888
« Reply #35 on: July 02, 2021, 12:26:27 AM »
Time for the engine. A few photos of all the bits prior to fitting. Im just waiting for a few bits to finish it off. First photo is the nova 6 speed gearbox. Those with an eagle eye may notice the shift drum end is incorrect. Was sent a 350 drum by mistake. Nova were great to deal with swapping for the correct unit instantly. Using the nova gearbox requires a bit of modification to the shift forks. I found a company in Italy who manufacture new forks as NOS is difficult to find. GBmotosports. A quick shave on the lathe and the forks work beautifully.
« Last Edit: July 02, 2021, 01:05:15 AM by Daggless888 »
Offline Daggless888
« Reply #36 on: July 02, 2021, 01:10:49 AM »
Crank was sent off for balancing and we removed 1kg while we were at it. Was then sent off for Superfinishing and ready to go.
Offline Daggless888
« Reply #37 on: July 02, 2021, 01:23:38 AM »
Conrods and pistons are Davies. Pistons are 2 ring slipper. Rods are 2mm longer than standard. They use this combination in their “short stroke” configuration.
Offline Daggless888
« Reply #38 on: July 02, 2021, 01:35:23 AM »
So everything bolted up nicely with new bearings throughout. I got all excited when I put the gearbox in that I forgot to take any photos before sealing it up. Gears change as they should and the crank spins nicely.
« Last Edit: July 02, 2021, 01:37:28 AM by Daggless888 »
Offline Daggless888
« Reply #39 on: July 02, 2021, 01:45:41 AM »
I’ve just dropped the cylinders off at the machine shop to have new liners fitted along with nikasil coating and have them oringed for use with copper gasket. Next I need to sort out the head.
« Reply #40 on: July 02, 2021, 11:13:56 AM »
Wow. This is going to be one heck of a motor.
Offline Daggless888
« Reply #41 on: July 02, 2021, 03:04:10 PM »
I’m aiming for 60 hp with a total dry weight of 135kg. I’m on target for the weight so it will be interesting to see how we go with the motor.
Offline Old Scrambler
« Reply #42 on: July 04, 2021, 11:37:07 AM »
2mm longer rods.............assuming oem stroke..........will you have to shape the chambers?
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Online Don R
« Reply #43 on: July 04, 2021, 09:18:42 PM »
 The piston pin is likely raised to allow for the extra rod length.
Offline Daggless888
« Reply #44 on: July 05, 2021, 12:58:39 AM »
No modifications for the chambers needed. Don is spot on. Pin is higher to allow slipper piston design. I will take a side on photo once they return from machine shop.
« Reply #45 on: July 05, 2021, 05:52:34 AM »
Mike R at JMR has helped Brent Waller build a CB550 with 76 hp at the rear wheel. Magician with head work when you are ready for more hp.
Offline Daggless888
« Reply #46 on: August 05, 2021, 06:59:23 AM »
Cheers RAFster. Have been in touch with mike. 👍
Offline Daggless888
« Reply #47 on: August 05, 2021, 07:09:11 AM »
As I’m waiting for the cylinders to return I’ve finished off the wiring. Have used the ignitech programable ignition along with a smiths Motorsport tacho.
Offline Daggless888
« Reply #48 on: August 05, 2021, 07:14:18 AM »
Cockpit view. Might be a bit ambitious with 14k on the tacho!
Offline Daggless888
« Reply #49 on: August 05, 2021, 07:25:19 AM »
Backend of the tacho is not so pretty yet. Just working out which wire to keep so I can get rid of all the others. We also have to run a lanyard style kill switch.
