Author Topic: What other seats fit a 550F frame?  (Read 355 times)
Offline Scott S
« on: February 16, 2019, 03:39:19 PM »
 I know the F model used a different seat than the K model. But the F frame shares some similarities with the later '77-78 K frames.
 What other seats work with the F frame? Do the latch and hinges from any other models line up?
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Can550
« Reply #1 on: February 16, 2019, 04:21:16 PM »
77/78 will fit fine if you are ok with bulky look. I have one if you want
4into1 has a good reproduction seat.
« Last Edit: February 16, 2019, 06:44:18 PM by Can550 »
Re: What other seats fit a 550F frame?
« Reply #2 on: February 17, 2019, 10:17:37 AM »
The F grab bar won't work the 77-78 K model seats.  Will need to change that, too.  If I recall, the F tail light housing gets hit too.  So, you might need the rear fender and tall light for the swap, too.
The seat for the 77-78 has more comfort for the passenger than the F seat.  So, I'm told by passengers.
The early k seats will fit to frame, too.  But, interfere with the bigger F tank.  Early tank fixes that issue.  There is still a grab bar style change to go with the seat to consider.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #3 on: February 17, 2019, 12:37:13 PM »
Any 550 seat works with the frame. It's the tank that matters
