SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
1973 Honda CB500 Speedometer/Tachometer Bracket
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: 1973 Honda CB500 Speedometer/Tachometer Bracket (Read 2458 times)
Nomad
Full Member
on:
February 21, 2019, 08:24:42 PM »
I recently purchased a speedometer and tachometer that came off a 1976 Honda CB550, to install on my 1973 CB500, however the mounting bracket is not compatible. I’m finding a few used brackets online that look as though the mounting holes will line up that are listed as part #M2. Can anyone confirm if this part number will fit the 1973 CB500?
Logged
bryanj
Really Old Timer ...
CB500 Number 1000036
Re: 1973 Honda CB500 Speedometer/Tachometer Bracket
Reply #1 on:
February 22, 2019, 04:07:41 AM »
No such part number as that on Hondas
Logged
Nomad
Full Member
Reply #2 on:
February 22, 2019, 05:52:53 AM »
Regardless of part number, will a 1975 CB500 bracket mounting holes match up to a 1973 CB500?
Logged
Gurp
I'm no.......
Master
Once was a...
Reply #3 on:
February 22, 2019, 06:22:11 AM »
I just pulled this bracket off my 73 500-4.
Logged
slow Progress
74 cb550.
Poor boy chop
73 CB500 chop
"Alley Cat" 93 sportster
Nomad
Full Member
Reply #4 on:
February 22, 2019, 06:31:23 AM »
Thanks for the info, the bracket that I purchased from the CB 550 almost worked but I need a bracket where the mounting holes are spaced further apart. It looks like the second picture I posted should work.
Logged
Gurp
I'm no.......
Master
Once was a...
Reply #5 on:
February 22, 2019, 09:04:50 AM »
Is it a 4 or a twin you need the bracket for?
Ifs its a 4 i can help you out.
Logged
slow Progress
74 cb550.
Poor boy chop
73 CB500 chop
Nomad
Full Member
Reply #6 on:
February 22, 2019, 01:11:27 PM »
It is for a four.
Logged
bryanj
Reply #7 on:
February 22, 2019, 01:23:22 PM »
The top tree on a 76 550 is the same part as a 500 so if the bracket dont fit it can only be:-
One of the top trees is wrong
The bracket is bent
The parts have been sold wrongly
Logged
Nomad
Full Member
Reply #8 on:
February 22, 2019, 02:32:10 PM »
I will look closer at the configuration of the tree when I get home.
Last Edit: February 22, 2019, 02:35:09 PM by Nomad
Logged
Nomad
Full Member
Reply #9 on:
February 23, 2019, 08:39:23 AM »
Looks as though the issue is the top tree. Any suggestions on what speedometer bracket I need? The distance between the mounting holes on the top tree is about 5 3/4 inches.
Logged
bryanj
Reply #10 on:
February 23, 2019, 09:12:07 AM »
God knows what that tree is off, would be easier to change the top tree, any 500 or 550 from 71 to 76 will do
Logged
jakec
Master
Reply #11 on:
February 24, 2019, 10:17:23 AM »
The bracket you have (grey one) looks exactly like the one on my 1975 400F.
Logged
1970 CB750 K0
1977 CB750 Chop
1984 Big Twin Evo Chop
1997 XR650L
Nomad
Full Member
Reply #12 on:
February 24, 2019, 10:19:54 AM »
The guy I purchased the speedometer, tachometer and bracket said it came off a 1976 CB 550.
Logged
jakec
Master
Reply #13 on:
February 24, 2019, 02:20:35 PM »
Could have been a 550 super sport. The super sport has a free floating frame that holds the blinkers and headlight (no fork ears). This thing plugs into that part. Prts #472 and #246 below
Logged
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
bryanj
Reply #14 on:
February 24, 2019, 02:37:07 PM »
That parts diagram looks like 400 not 550 to me.
Logged
jakec
Master
Reply #15 on:
February 24, 2019, 03:09:37 PM »
Yes it is the 400, sorry. Just showing that the parts look the same.
Logged
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
