Author Topic: Greetings from Estonia! splitter's 1974 CB500 Four  (Read 1142 times)
Offline splitter
« on: February 24, 2019, 04:59:23 AM »
Hi there!
I've been a fan of Honda's CB Fours for a few years now but it took me about two years to pull the trigger on a deal to aquire a nice CB500 Four from 1974 (MY1973). Somehow I like the CB500 more than its big brother.
I’m a mechanical engineer by trade and have been working on and with different kinds of machinery from my childhood. I’ve owned/repaired/restored about 30 motorcycles (mainly vintage/classical) and been riding them from when I was 12 years old. Tinkering on tractors/cars/motorcycles and other machinery has always been a part of my life. But since last year’s September, I haven’t owned any classical Japanese bikes.
I purchased this beauty from Finland in September 2018. I believe it to be an European K1, but as I know these European export models were assembled with parts from various production years. So in US standards it’s not a pure K1, more like mix of K0/K1/K2. Some parts have certainly been replaced as the bike has seen some smaller crashes and a repaint.
More on the bike. It’s first registered in April 1974 but model year is still probably 1973. According to the papers the bike has done over 104 000 kms. I’d figure that the engine has seen an overhaul sometime during these kms? When I went to see the bike it was running on three cylinders, front brake was sticking which made the clutch slip a bit and the tires were almost 20 years old. When the engine warmed up, some small oil leaks came apparent. The PO said that the bike had been basically been sitting for over 13 years. I still liked the looks and the feel of this CB500 and ended up buying it.
Sticking front brake ended up being a blocked pressure relief hole in master cylinder. Ended up flushing and cleaning the whole system. All the seals and pistons looked really good on both master and slave.
I pulled the carbs and cleaned them. Carburetor for cylinder #3 had a clogged idle jet and all of the float bowls were full of petrol residue (resin-like substance). Rubber boots which connect the carbs to the intake manifold were hard as a plastic.
Replaced spark plugs and caps, cleaned air filter. I also bought NGK J1 cable splitters as the ignition wires were falling apart between my hands.  Tires are now Heidenau’s K36 (rear) and K44 (front).
After doing a small tune-up (adjusting timing, valve clearance etc) I got it to run on all of the four cylinders. I drove it around for few hundred kilometers to get a feel for it and I started to experience more and more oil leaks and a ’lean hang’. Revs were not coming down to idle and synchronizing carbs became almost impossible. Also I didn’t like how the engine sounded (chains’ rattle) and clutch was not engaging smoothly. I took a decision to pull the engine before spring to check its overall condition and replace what’s needed (at least bearings, gaskets etc). Maybe do an overhaul to the carbs as well. Right now I’m about to move the bike into my man-cave to pull the motor. I would definitely appreciate your help on checking the common faults on the engine and finding parts.
Mods, which of the sub-forums is best for this kind of small ’project’?
BR,
splitter
Re: Greetings from Estonia! splitter's 1974 CB500 Four
« Reply #1 on: February 24, 2019, 11:17:14 AM »
Welcome from Texas, nice job on the 500, looks great.  Do you know what handlebars those are? I have a 500 project bike and would like to use those.
Start your project thread in "Project Shop" here....
http://forums.sohc4.net/index.php/board,103.0.html
PS. Are you near Tallinn?  I've seen pics of the Tower....very cool
Offline bek1966
« Reply #2 on: February 24, 2019, 11:38:20 AM »
Welcome from Wisconsin.  Great looking 500!  The original 4 into 4 exhaust pipes are my absolute favorite,  they really add to the character of the bike.
I'm looking forward to following your progress.
Brad K
« Last Edit: February 24, 2019, 02:27:39 PM by bek1966 »
1971 CB750 K1 - Candy Gold
1971 CB500 K0 - Star Light Gold
1974 CB350 F1 - Glory Blue Black
1975 CB550 F0 - Someday "ProtoSport"
Pleasant Prairie, Wisconsin
Offline splitter
« Reply #3 on: February 24, 2019, 12:04:20 PM »
 Thanks for the warm welcome, guys!
I'm not sure about about the handlebars but they do look nice ;)
I live about 100 miles from capital city Tallinn, the whole old town is amazing  8)
I managed to pull the engine today. Also had a quick peek into the gearbox. But more on that when I make my own 'project' topic.
« Reply #4 on: February 24, 2019, 02:41:48 PM »
Welcome aboard  very nice bike.
 The bars look like 400 four or superbike.
The brown spot showing through the blacks is that worn through from the knee.
 I would leave its it looks well earned and part of the story on a bike with lots of miles. .
 Enjoy the bike..
Offline MD
  • Living in the North Woods overlooking The Lake.
    • MN North Woods
« Reply #5 on: February 24, 2019, 04:35:35 PM »
Welcome from Lake Superior,
There are people up here that like Lutefisk.  I much prefer riding motorcycles.
-MD
1975 CB550F Super Sport;  Lake Superior Circle 1000, 45-90 Saddle 1000, All in Yooper 1000 and SS 2000 in 48 hrs:  1985 GL1200A, MN in State SS1K
Offline splitter
« Reply #6 on: February 25, 2019, 12:11:50 PM »
 Enjoy the bike..
Thanks for the kind words!
Actually I really like bikes which show their miles and have aged well more than shiny new bikes. I'm a so called 'oiler' who like his bikes original and with dings and scratches that add character to the bike. Maybe someday I'll show my other 'oiler' projects as well.
Anyway, I'm continuing my CB500's small rebuild in project forum. Link here if you'd like to follow http://forums.sohc4.net/index.php/topic,176346.0.html
