Ok so you have a 77 or 78 K front hub.
A disc adaptor.. is it steel ?
Adaptors on axle to fit larger fork holes
Stock Speedo drive, that looks, like it was not used to drive the cable.
So it looks like it worked but the spacer adaptor is a bit crude, not a lot of meat around the disc mount holes. And it looks like it does not fit nicely to the hub, which would centre it and keep things running true.
I have made many adaptors similar to that , and they work well , but the fit should be better..
What is wrong on wheel ? Rim bent L
