Author Topic: New re-bored cylinders  (Read 1336 times)
Offline skidsolo
« on: February 27, 2019, 07:43:12 PM »
I just got my cylinders back from reboring and noticed (now they are clean) the linears are all about 0.01" proud of the aluminium cylinder is this normal? They are all even.
Re: New re-bored cylinders
« Reply #1 on: February 27, 2019, 08:00:48 PM »
Warm it up  and push them down..
Offline slikwilli420
  • Master of Disaster
« Reply #2 on: February 28, 2019, 07:28:22 AM »
Do as Frank suggests then have it decked just so you know its flat and true.
« Reply #3 on: February 28, 2019, 02:01:15 PM »
Did the shop remove them? If the sleeves are now proud of the deck when originally they were not, then something is amiss.
Call the shop and ask if/why they were removed.
I have experienced this a couple times. If it's not looked after the sleeves MAY or may not slip into place when the engine heats, so if you mill the deck flat and then the sleeves sink, the head gasket will leak.
If they removed them, they likely tried to press them back. (often what happens) The sleeve top flange outer edges are sharp and when pressed can roll a little aluminum ahead of the flange and even if you heat them now they may not bottom.
The best solution (if you have a gas BBQ or an old oven) is to invert the cylinder and support with some 2x4" steel tubing (or whatever) but not the flange, so the sleeves can drop out. First remove the sleeve bottom o-rings. Preheat the BBQ to 450, place your cylinder on the steel supports and wait for the sleeves to drop. Could take 10 15 mins.
Then lightly sand the sharp flange edges and clean everything, including any aluminum burrs. To speed the process put the sleeves in a freezer for a while. Now cylinder top side up, and on the supports, warm the cylinders to 450 again. With oven mitts on GENTLY let the sleeves drop into the cylinder. Don't let them fall unsupported because the flange can easily crack. Once in place I usually gently tap  around the flange top with a plastic hammer to be sure they're seated. You'll hear if they've bottomed.
It will still be a good idea to mill the deck flat after. Install new sleeve bottom o-rings.
Offline skidsolo
« Reply #4 on: March 23, 2019, 06:46:17 AM »
I put them on the grilll and the liners came right out. I cleaned them up and removed all carbon and debris. I then did as suggested reheated poped them right back in. I checked with an engineers steel rule and they are now dead flush. Thanks for your ideas it worked.
