Author Topic: 16" on the front of my 550?  (Read 1896 times)
Offline Shtonecb500
    • Youtube profile
« on: March 02, 2019, 03:20:50 PM »
gsxr swap up front on my 550 and already running a 16" hog wheel in the rear. Any reasons why I shouldn't run 16 front and back?
Using Dyna hub between the forks and found a set of 16" harley wheels for 100 bucks.
thanks.
« Last Edit: March 02, 2019, 03:23:47 PM by Shtonecb500 »
Offline WhyNot2
  • I'm finally an
Re: 16" on the front of my 550?
« Reply #1 on: March 03, 2019, 05:21:47 AM »
pix or it didn't happen.......
Offline Bankerdanny
  • Endeavor to persevere
« Reply #2 on: March 03, 2019, 07:16:41 AM »
I suppose it depends on what tire you run. Dropping 3" in diameter is a lot and will change up the steering geometry. Give it a shot if you want, but ride carefully until you understand how your bike reacts to the change.
« Reply #3 on: March 03, 2019, 07:34:23 AM »
 I thought one complaint against 16" fronts when they hit the scene back in the day for a little while was a lack of choices of rubber.
« Reply #4 on: March 03, 2019, 10:43:33 AM »
We are putting a 16 front on a 78 750 K with GL forks.
 Using a nighthawk rear wheel. , height us very close, different axle size.
 Your Harley wheels wil, likely be 3/4 inch bearings or 1 inch Maybe 25mm .
What size are your fork ends ?
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #5 on: March 03, 2019, 04:54:07 PM »
Just go with the gsxr stock size.  Lots of great front tires available for that rim.
If you go to 16 front, you'll be severely limited in choices and design quality.
Offline Shtonecb500
    • Youtube profile
« Reply #6 on: March 07, 2019, 11:13:12 PM »
Im not sure what you mean by fork ends, I installed 25mm bearings in the hub already and it fits the stock GSXR axle.
Offline Shtonecb500
    • Youtube profile
« Reply #7 on: March 07, 2019, 11:14:13 PM »
Yeah I think I'll just try it out and see how it feels, the most overwhelming negative is lack of tire choice.
Offline Shtonecb500
    • Youtube profile
« Reply #8 on: March 07, 2019, 11:15:33 PM »
Lol, I'll post some pictures after the weekend.
« Reply #9 on: March 07, 2019, 11:25:47 PM »
What size are the fork ends where the axle is clamped ?
 Sounds like one  might  be threaded .
If your bearings in wheel fit the axle you are fine, just need a spacer on each side..
« Last Edit: March 08, 2019, 01:06:23 AM by 754 »
  • Holy Cow! I'm a
« Reply #10 on: March 09, 2019, 11:56:47 PM »
I'm recalling the few times i rode a buell blast and the somewhat odd but not unstable handling of that 16" front
« Reply #11 on: March 10, 2019, 12:30:54 PM »
I rode a  1125R Buell  feltvreal funny in corners 22 deg rake.
  • Holy Cow! I'm a
« Reply #12 on: March 10, 2019, 06:29:11 PM »
Thats a steep angle even for a race bike
« Reply #13 on: March 10, 2019, 07:45:48 PM »
 I checked its 21, 3.3 inches trail.
  • Holy Cow! I'm a
« Reply #14 on: March 12, 2019, 09:48:48 AM »
Eric must've wanted the bike to steer like a cheetah
