Author Topic: Can we play "Name that Part" Brake Edition?  (Read 1026 times)
Offline OldZaskar
« on: March 05, 2019, 10:02:56 AM »
I dug into the rear wheel - to inspect the brakes, bearings, etc. As expected, it was a mess - grease, dirt, brake dust, etc. So, I started carefully disassembling and cleaning the parts. Well, I thought I was being careful - but I missed these two. They were just laying there with the other pieces - and I didn't see where they fell from. And, I've gone through manuals/exploded views and parts lists (with pics) and can't find them.
Actually, I'm not even "them" is accurate - it could be an "it" that was torn in two. But, they are oddly similar to have ripped.
From the rear hub/brakes on a '73 CB500
Thanks!
'73 CB500 Four
Offline Bodi
Re: Can we play "Name that Part" Brake Edition?
« Reply #1 on: March 05, 2019, 10:09:51 AM »
Not looking familiar. I think there should just be the two shoes and the springs in there. Could be wrong, of course.
« Reply #2 on: March 05, 2019, 10:25:59 AM »
Looks maybe like the felt seal on outside of brake shaft.. where it meet the arm.
 There is a recess in the backing plate, that it sits in.
« Last Edit: March 05, 2019, 11:00:22 AM by 754 »
« Reply #3 on: March 05, 2019, 10:30:40 AM »
+1
Offline BenelliSEI
  • 1969 cb750
« Reply #4 on: March 05, 2019, 11:03:44 AM »
+2....... nothing else even looks remotely like that!
Offline OldZaskar
« Reply #5 on: March 05, 2019, 11:04:25 AM »
Well, I guess I should've added that it's rubber. Were rubber versions of those felt seals available in the aftermarket maybe?
'73 CB500 Four
« Reply #6 on: March 05, 2019, 11:18:46 AM »
Nope and nothing rubber in the back brake of a 500
Offline jaytee-nz
« Reply #7 on: March 05, 2019, 11:24:28 AM »
Looks like two separate pieces and not two halves of the same item. If you imagine the two pieces joined together, they don't form a circle.
Maybe the PO installed them for some reason ?
Are you sure it's a CB500 rear wheel ?
« Reply #8 on: March 05, 2019, 11:26:56 AM »
 We'll if you can't find felt, you use what you can .. see if it fits in there.
