I'm afraid not. Extra, not metered fuel can pass there and will greedily be sucked into the combustion chamber by the down going piston which will result in an overrich mixture.
Cross drilled open tip is what I have.
So far all that have the 087A carbs - that
we have asked - have the same cross drilled open tip airscrew, so you're no exception. Reason I asked, is, when you study the CB550, K1, K2 Parts List*, you will learn that the
only part in the 087A carbs that's listed as different (and so would explain the different carb number) is the airscrew. But... sofar nobody reported they actually
have them, which lead us to believe that what was planned, maybe never has been materialised. Leaves the theoretical possibilty that maybe the jet needle was hung differently. So far we have no reports that confirm this.
Carb body stamped 087A. So to clarify, you think I can interchange one 022A with three 087A’s and have no issue?
If you have a complete rack of 022A, why not change the rack in total? If you don't have a complete rack, you could use just the one, provided it's exactly the right one to position in there. In other words: is it a #1, #2, #3 or #4? If you have all carbs on the table with the floatbowls removed, you could verify the jet needles are all hung equally. It's not difficult. When you remove the main jets, you can see the tips of the needles. You could use a simple measuring caliper to check. No need to open the top lids. Not yet.
* Page C10 Ref No. 7 in
http://www.honda4fun.com/pdf_parts_list/pdf_spac550/CB550-K0-K1-K2/CB550-K0-K1-K2_04.pdf
