Author Topic: cam tower bolts  (Read 1462 times)
Offline fireman1073
cam tower bolts
« on: March 14, 2019, 07:15:00 AM »
on the 750, the cam towers have studs and bolts, is there any reason not to run all studs? bolts can pull the threads so studs are usually better
« Last Edit: March 14, 2019, 07:17:32 AM by fireman1073 »
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: cam tower bolts
« Reply #1 on: March 14, 2019, 07:25:47 AM »
You can run all studs, but all studs makes cam install a little tougher. Not impossible, just less room for fanagalin'...
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Re: cam tower bolts
« Reply #2 on: March 14, 2019, 08:28:28 AM »
 Be forewarned that those bolt holes can be fragile and prone to stripping the threads if your not careful. Think some people,especially if building a hypo engine go right to a heli-coil or other fix procedure to eliminate that possibility.
Offline kmb69
Re: cam tower bolts
« Reply #3 on: March 14, 2019, 08:58:22 AM »
ALL STUDS? Be tough!
Maybe, but you will have to assemble and disassemble it all as a set, with the rockers and cam "installed" on account of the 4 bolts that go through the rocker shafts.
Plus one on what Wilbur said if you mean just the 8 camshaft cap bolts.
Offline slikwilli420
  • Master of Disaster
Re: cam tower bolts
« Reply #4 on: March 14, 2019, 09:08:58 AM »
I did the opposite. Im running all bolts with Timeserts in the threads. Now I have 180,000 PSI ARP bolts into steel threads. No way they are coming loose or pulling threads now.
Offline fireman1073
Re: cam tower bolts
« Reply #5 on: March 19, 2019, 10:52:01 AM »
yeah i meant just the 8 cam cap bolts...thanks guys
Re: cam tower bolts
« Reply #6 on: March 19, 2019, 02:07:23 PM »
Assemble as a “set”? To do that you would have to break the cam chain... YUCK!  :P
TAMTF...
Wilbur
Projects:
Re: cam tower bolts
« Reply #7 on: March 19, 2019, 02:56:29 PM »
 Speaking for the peanut gallery, the concensus seems to be use the studs and bolts but timesert/helicoil the 4 bolts.  I have one tapped to 1/4-28. I dislike it but it works.
