This is bearing 23 on the diagram. Part no. 91003-235-000. It’s the last bearing on the main shaft that sits on the edge of the case and is oiled by the countershaft bearing retainer. I did check to make sure the thrust washer between gears 5 and 2 is there and it is.
I believe that the washer labeled 17 part no. 90458-292-000 is in place as well. It was in a numbered ziplock bag that I have a photo of. And the bag and part are gone, which should mean it’s installed, but you can’t visually see the part.
Order of the gears is F, 1,4,3,2,5 for reference.
