Author Topic: Oil Change After Sitting For 3 Years  (Read 1109 times)
Offline campbmic
  • Sea-Foam and Flaming 151 is a dam good
« on: March 24, 2019, 04:09:34 PM »
Hey everyone! So my 1975 CB550 has been sitting for about 3 years, without running. When I parked it, it was already due for an oil change. Its currently not running. Is there anything extra I should/could do when changing the oil, to make sure I get all of the old nasty stuff out?
Typically I run the bike for a minute or two before I change the oil to warm everything up. Since its currently not running I cant do that. Should I wait on the oil change, until I get it running? I dont know if running it with the current oil in is a good idea, since its pretty nasty.
Its hard to be wrong when you know nothing!
Bobarama
Re: Oil Change After Sitting For 3 Years
« Reply #1 on: March 24, 2019, 04:12:09 PM »
I would drop the oil put in fresh oil get it running drop the oil and filter and be done.
Offline BenelliSEI
  • 1969 cb750
« Reply #2 on: March 24, 2019, 04:23:00 PM »
+1 to Bobarama. Oil is cheap. Even if you don’t get to work on it soon, dump the old oil. There are corrosive contaminants in there.......
Offline campbmic
« Reply #3 on: March 24, 2019, 04:25:24 PM »
so 2 oil changes is what youre saying?
Bobarama
« Reply #4 on: March 24, 2019, 04:26:42 PM »
Yes two oil changes . 1 filter.
Offline BenelliSEI
  • 1969 cb750
« Reply #5 on: March 24, 2019, 04:40:19 PM »
........assuming you get it running and warmed up between the oil changes.
« Reply #6 on: March 24, 2019, 07:01:05 PM »
 First thing I ever do when I get a new project, and most are not runners, is to dump whatever oil is in it and start with fresh and a new filter then work on the carbs and other things to get it up and running. Second oil change can happen after some miles.
Offline Deltarider
« Reply #7 on: March 25, 2019, 09:16:52 AM »
In your case I would just drain the old oil without first warming the engine. Everything that's not in suspension will be at the bottom of the oilpan by now and so will be flushed out. Just refill with new oil. Done.
CB500K2-ED Excel black
