Author Topic: '77 CB750 K7 Pistons  (Read 1345 times)
Offline Bl4ckC4t
« on: March 30, 2019, 12:15:04 PM »
Does anyone have any idea where to source pistons for the K7? The one I am buying is seized and I am gathering prices for all the potential needed parts to get it running. However, I am having trouble finding pistons that match OEM for the '77. Any help would be appreciated.
Offline robvangulik
  • Honda Fourever
Re: '77 CB750 K7 Pistons
« Reply #1 on: March 30, 2019, 01:23:42 PM »
What sources did you try, before asking?
Www.cmsnl.com....
Offline Bl4ckC4t
« Reply #2 on: March 30, 2019, 03:36:40 PM »
Vintagecb750, and similar sites, including the one you listed.
No one seems to have any actual pistons at standard size for the 1977.
Pretty much everyone ends at 76, and under my understanding, 76 and 77 have different sizes due to the compression ratio.
Offline Airborne 82nd
« Reply #3 on: March 30, 2019, 05:01:26 PM »
If I'm reading this right it sounds like you have not broken the engine down yet. Don't waste time you may not need them in fact you may not need anything. It could be a boat anchor. I hope not. But if it is seized I would take it apart far enough to see why it is stuck. Then you can make a better list.
Offline Bl4ckC4t
« Reply #4 on: March 30, 2019, 05:45:33 PM »
You are correct, I have not tore it down yet. I am actually waiting on the owner to have title in hand. However, I am only looking in the event that I have to swap pistons. I know the cause of the sieze, but not the extent. It was left outside for a period of time without spark plugs in the rain. While I am hopeful for an easy recovery, I just want to plan for the worst and hope for the best.
« Reply #5 on: March 30, 2019, 10:41:33 PM »
I would pull the pan to see how bad the water damage is at the bottom end that would concern me more than the top depending how long water has been in it. I don't know why someone does that ::) Good Luck
« Reply #6 on: March 30, 2019, 10:52:34 PM »
Head will most likely need to be refurbished. All seats to be cut. Exhaust valves with guides might need to replaced.
Offline Bl4ckC4t
« Reply #7 on: March 30, 2019, 10:54:24 PM »
Thanks lieutenant. I will keep that in mind, and thank you for your service. Also thank you for the hard work you put into that batt.
Offline Bl4ckC4t
« Reply #8 on: March 30, 2019, 10:56:22 PM »
Had this feeling, but I really hope that it isn't going to be too much more than this.
« Reply #9 on: March 30, 2019, 11:31:06 PM »
Take it apart before deciding. Bores might be damaged, bigger pistons to be used. Or it might have bigger bores than stock.
If OK and bike to be stock.
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F132002710167
Offline Bl4ckC4t
« Reply #10 on: March 30, 2019, 11:50:59 PM »
I will keep that in mind. However, those are .5 over, would that be a problem?
« Reply #11 on: March 31, 2019, 03:29:07 AM »
If the pistons are stuck chances are it will need aeebore anyway.
Offline Bl4ckC4t
« Reply #12 on: March 31, 2019, 08:50:47 AM »
Good point. Thank you!
« Reply #13 on: March 31, 2019, 09:18:01 AM »
Fresh bore, new pistons with correct clearance and ring gaps plus a refurbished head will make  good.
Inspect status first. When at it replace both chain tensioners that probably are hard and have left rubber parts in oil pan.
These old engines need some new parts due to age, not only usage. Good idea to read Hondaman's CB750 book before
Offline Bl4ckC4t
« Reply #14 on: March 31, 2019, 10:56:10 AM »
Talking about this one? ttps://www.amazon.com/CB750-book-Putting-Them-Back/dp/0557310237/ref=asc_df_0557310237/?tag=hyprod-20&linkCode=df0&hvadid=317002210742&hvpos=1o1&hvnetw=g&hvrand=6498158319411224404&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=9024228&hvtargid=pla-624928938144&psc=1
« Reply #15 on: April 01, 2019, 12:01:10 AM »
Yes, look for the Hondaman book thread with link to how to purchase with coupon
http://forums.sohc4.net/index.php/topic,65293.425.html
Offline Bl4ckC4t
« Reply #16 on: April 01, 2019, 01:30:39 PM »
Thank you PeWe
