Author Topic: Ignition coil....condenser?  (Read 1124 times)
Offline hsas.69
« on: April 09, 2019, 03:45:16 PM »
Im pretty sure i have an ignition coil bad wanted to ask around as well. 78 CB550K stock ignition, stock carbs rejetted for foam filter and exhaust. Runs great until things get up to temp, then starts to develop a light throttle miss. If i grab a handfull it pulls fine. The miss gradually gets worse until two cylinders are just dead. All within a short warm up and probably five or six miles of cruising.
Tried a new set of plugs i had already just in case. Anyone think of anything other than a coil that im not thinking of.
Sent from my LG-LS993 using Tapatalk
78 CB750 F3
78 CB550 K4
Offline johans
    • corporate leather
Re: Ignition coil....condenser?
« Reply #1 on: April 09, 2019, 03:51:58 PM »
condenses fail when they warm up , ask me how i know. Go for original points,plate and condensers . It will save you a lot of grief..
1978 CB750K
1976 CB750F SS
1978 CB750F
1979 Honda 400T
1979 BMW R65
1979 Kawasaki KZ400
2003 Ducati Monster 800 SIE
1988 Suzuki GSXF
Kawasaki 200 KDX
Yamaha YZ 250F
1986 Kawasaki KZ 900
Kawasaki Lakota 300 ATV
« Reply #2 on: April 09, 2019, 04:55:50 PM »
Add Hondaman ignition module too and less need for condensers.
My last CB750 K2 build had a behavior where  I suspected the very old condensers so I disconnected them. It runs fine without them.
My K6 got some occasional misfires at around 8000-9000 rpm without condensers.
Offline hsas.69
« Reply #3 on: April 09, 2019, 04:56:50 PM »
I thought maybe a condenser. For the cost wouldnt hurt to try some before doin coils.
I might try that PeWe unhook them and see.
78 CB750 F3
78 CB550 K4
« Reply #4 on: April 09, 2019, 05:39:42 PM »
The coils.  Literally two coils of insulated copper wire in physical proximity.  Rather Hard to kill without physical abuse.
Condenser: two layers of conductive foil separated by an insulating material.
Condensers far more likely to fail with time (dry out) and use (arcing between plates due to insulating material breakdown).
Offline jgger
« Reply #5 on: April 09, 2019, 06:11:12 PM »
I would say it could be either one, condenser is cheaper to throw at it than a coil. Switch the condensers and see if the issue follows. If it does then condenser, if  it doesn't then most likely coil.
I had one go bad from moisture, it would run like a raped ape until it got warm then it would quit. Cool dod and back to running great until it got warm again. It wasn't a SOHC Honda, but the principal is the same.
Good luck.
Offline Jore
« Reply #6 on: April 09, 2019, 06:21:30 PM »
I used ford pinto condensers, iirc they where for a '74 model the 2.4L one
1975 CB400F owner
-Having a vintage motorcycle is like having a moody girlfriend.
My 466 build: http://forums.sohc4.net/index.php/topic,146494.0.html
« Reply #7 on: April 09, 2019, 06:32:36 PM »
You must have Hondaman ignition for that. Stock ignition must have condensers.
Offline Spanner 1
« Reply #8 on: April 09, 2019, 06:50:35 PM »
In the 10 years I've been on this Forum I can't even remember a case of a bad coil ! They just don't fail even after 50 years like my K1 750. Condensers and heat, absolutely . The bummer is any condensers your gonna' buy in 2019 are going to be ( very ) old stock and already dried up IMO ;). So, the ultimate ignition for our old bikes is Hondamans 'ignition booster' in tandem with the stock points. Suits the charging system ( very important ) and you can do away with the condensers . If you make that mod be sure the points plate gasket is solid as any moisture at the points is a no-no due to the much reduced current across the points which can be interrupted by condensation in there. Good luck !
« Last Edit: April 09, 2019, 06:59:08 PM by Spanner 1 »
